公告
IPPS & Purify
Deleted_U_Intel
1,407 次查看
I'mrunningRational's Purify againt myapplication built withVS .NET-2003/ IPPS 4.x and I'm getting numerous warnings on IPPS implementations.
Here's an of example:
Beyond stack write in a6_ippsLog10_32f_A11
Questions:
1) Is IPPS tested with Purify / BoundsChecker?
2) Is there a listing of all IPPS Purify issues so I can determine which
errors / warnings I should be concerned about and which ones I can safely
filter out?
TIA
0 项奖励
1 回复
Vladimir_Dudnik
1,407 次查看
of course we do test our implementation, but if you think you found some bug in IPP please submit it through technical support. We will check this issue and inform you about results.
Vladimir
0 项奖励
回复
