Ipp complex/float multi-rate FIR filter usage
Ionen__Vlad
Hi there,
I am using ippCore 2018.0.1 (r56998) and tried to initialize the multi-rate FIR filter specification structure for the Ipp32fc (complex) source/destination vectors and the real Ipp32f (float) filter coefficients, but ippsFIRMRInit function generates error about real float filter coefficients type. How can I configure multi-rate FIR filter for processing complex data with real float filter coefficients?
Vlad
Andrey_B_Intel
Hi Vlad.
As workaround you can create temporal complex coefficient vector and zero its complex part. But may be we add special optimization of this case in next IPP releases.
Ionen__Vlad
Hi Andrey,
It would be nice to have the special optimization of this case in next IPP releases.
Vlad
Ionen__Vlad
Hi Andrey,
Please let me know when the special optimization of this case is available to use.
Vlad
