IppiRotate IppiGetRotateShift
giacomo_c_
Hi
From Ipp 8.2 documentation
1) IppiRotate :
angle : The angle of rotation in degrees. The source image is rotated counterclockwise around the origin (0,0).
IppiRotateCenter : ... This function rotates the ROI of the source image by angle degrees (counterclockwise for positive angle values)
while IppiGetRotateShift and AddRotateShift:
angle : The angle in degrees to rotate the image clockwise around the point with coordinates (xCenter, yCenter).
Positive angle is in opposite direction for the last 2 function?
2) While not documented function IppiRotateCenter can return also ( as warning I suppose) ippStsWrongIntersectROI. Is right?
Thank's
Giacomo C.
Valentin_K_Intel
Hi Giacomo,
Thank you for the questions.
1). I think that it is the misprint in the documentation. Positive angle is in the same direction for the all 4 functions.
2). The function ippiRotateCenter  can return the warning ippStsWrongIntersectROI. It means that the rotated processed image ROI
has no intersection with the destination ROI.
Valentin
