6827 Discussions
Is There A Function that can convert rgb 24bit to YUV420?
kantonwang
hi
There are some functions about converting from rgb to YUV420 in ippcc.h. Now I need a function convert rgb 24bit to YUV420. Is there?
Thanks!
kantonwang
I found it ippiBGRToYCbCr420_8u_C3P3R, i think it's ok.
Another question:
When I use UMC::VideoEncoder, there is memory leaks.
Detected memory leaks!
Dumping objects ->
{83} normal block at 0x003F7568, 1424 bytes long.
Data: < > CD CD CD CD 00 CD CD CD 00 00 00 00 00 00 00 00
My test source at VC++2003
UMC::VideoEncoder *pEncoder = UMC::createMPEG4VideoEncoder();
delete pEncoder;
Please tell me why it happend?
Thanks a lot!
peter
kantonwang
Maybe it's sample's bug.
At file umc_mpeg4_video_encoder.cpp Ln30, i think it should delete mp4enc. I modified and test it, there is no memory leaks.
peter
Vladimir_Dudnik
Hi Peter,
thanks for reporting about that issue, I've submitted your report to Intel Premier Support, so you will be automatically notified when that issue will be fixed.
Vladimir
