Issue when multiplying 0 to large arrays
Animesh
We came to find that multiplication of an array (F32, F64, I32) with a scalar of 0 leaves (most of) the array untouched. For F32, this behavior starts with array sizes of 2^29 and up; for F64, it starts at 2^28 already. For I32 also, the behavior starts from 2^29. We have also tried CF32 and CF64 but they seem to work fine (checked until 2^30).
Description
IPP Function
Number of elements at which issue occurs
F32 in place
ippsMulC_32f_I
2^29
F64 in place
ippsMulC_64f_I
2^28
I32 in place
ippsMulC_32s_Isfs
2^29
CF32 in place
ippsMulC_32fc_I
no issue observed up to 2^29
CF64 in place
ippsMulC_64fc_I
F32 out of place
ippsMulC_32f
2^29
F64 out of place
ippsMulC_64f
2^28
I32 out of place
ippsMulC_32s_Sfs
2^29
CF32 out of place
ippsMulC_32fc
no issue observed up to 2^30
CF64 out of place
ippsMulC_64fc
I have attached a standalone C++ code which reproduces the behavior.
The behavior was checked on IPP 2021.8.0.
The example code creates an array of fixed size. It runs correctly for F32 (until size 2^29-1), but will show the error for F64. Any larger array size will show the error for both.
Gennady_F_Intel
Yes, that's correct that not all IPP functions are available for platform - aware extensions ( to support of 64-bit integer size). In particularly, this ippsMulC_*.* is not available for platform-aware capabilities. We are continue to extend the list of such functions from case by case.
Wobo
Ok, I am no Intel staff. But I assume it has to do with that:
https://www.intel.com/content/www/us/en/docs/ipp/developer-guide-oneapi/2022-2/ipp-using-platform-aware-functions.html
This burden of the 32-bit size limitation of many many IPP functions is quite often dangerous for our 64-bit applications, where we have to deal with huge data sets. Creation of some platform aware 64-bit enabled functions are a good start by Intel, but my wish is make all IPP function properly usable in a 64-bit environment.
Kind Regards
Gennady_F_Intel
ShanmukhS_Intel
Hi Animesh Baranawal,
Thanks for posting in Intel communities.
Thanks for reporting this issue. We were able to reproduce the same at our end and we have informed the development team about it. We will get back to you with an update soon.
Shanmukh.SS
