6847 Discussions
JPEC2000 sample code build in C++ Builder problem.
jbinfo
I am used IMPLIB (on the DLL) to create an import library in the Borland environment, as follows:
implib.exe ippacpx.lib ippacpx-6.1.dll
implib.exe ippcc.lib ippcc-6.1.dll
implib.exe ippccpx.lib ippccpx-6.1.dll
implib.exe ippch.lib ippch-6.1.dll
implib.exe ippcore.lib ippcore-6.1.dll
implib.exe ippcv.lib ippcv-6.1.dll
implib.exe ippcvpx.lib ippcvpx-6.1.dll
implib.exe ippi.lib ippi-6.1.dll
implib.exe ippipx.lib ippipx-6.1.dll
implib.exe ippj.lib ippj-6.1.dll
implib.exe ippjpx.lib ippjpx-6.1.dll
implib.exe ipps.lib ipps-6.1.dll
implib.exe ippspx.lib ippspx-6.1.dll
implib.exe libiomp5md.lib libiomp5md.dll
implib.exe libmmd.lib libmmd.dll
implib.exe libmmdd.lib libmmdd.dll
then addall librayfileandJPEG2000 sample code(\image-codecs\uic\src\codec\image\jpeg2000,\image-codecs\uic\src\io,\image-codecs\uic\src\core) to my project,but i got a bunch linker error:
[Linker Error] Unresolved external 'DiagnDescrCT::Context() const' referenced from D:\INTEL_IPP\OBJ\UIC_JP2_ENC.OBJ
[Linker Error] Unresolved external 'DiagnDescrCT::Context() const' referenced from D:\INTEL_IPP\OBJ\UIC_JP2_DEC.OBJ
Can someone help please ?
best regards
JBH
Vladimir_Dudnik
It seems you did not link with UIC DLLs?
Vladimir
jbinfo
Quoting - jbinfo
then addall librayfileandJPEG2000 sample code(image-codecsuicsrccodecimagejpeg2000,image-codecsuicsrcio,image-codecsuicsrccore) to my project,but i got a bunch linker error:
[Linker Error] Unresolved external 'DiagnDescrCT::Context() const' referenced from D:INTEL_IPPOBJUIC_JP2_ENC.OBJ
[Linker Error] Unresolved external 'DiagnDescrCT::Context() const' referenced from D:INTEL_IPPOBJUIC_JP2_DEC.OBJ
best regards
JBH
Thank you reponse.
i am according of your indication to link UIC DLL as follow:
implib.exe uic_core.lib uic_core-1.0.dll
implib.exe uic_io.lib uic_io-1.0.dll
implib.exe uic_jpeg2000.lib uic_jpeg2000-1.0.dll
implib.exe uic_jpeg.lib uic_jpeg-1.0.dll
after add uic_core.lib, uic_io.lib, uic_jpeg2000.lib, uic_jpeg.lib to my project.
now, i am extra add three file dicom.cop. jpeg2k.cpp and jpeg.cpp to build project, but i got a bunch linker error:
[Linker Error] Unresolved external 'UIC::ImageColorSpec::~ImageColorSpec()' referenced from D:INTEL_NEW_DLLOBJJPEG2K.OBJ
[Linker Error] Unresolved external 'UIC::ImageBuffer::~ImageBuffer()' referenced from D:INTEL_NEW_DLLOBJJPEG2K.OBJ
[Linker Error] Unresolved external 'UIC::ImageSamplingGeometry::~ImageSamplingGeometry()' referenced from D:INTEL_NEW_DLLOBJJPEG2K.OBJ
How can i to deal with it?
thank for you help.
Regards, JBH
Vladimir_Dudnik
ImageBuffer destructor should be defined in uic_core.lib
Might be the difference in C++ name mandling between MSVC and BC cause this effect?
Vladimir
jbinfo
Quoting - jbinfo
best regards
JBH
I am change develop tool by MSVC to package dll, and call LoadLibrary function in BCB, thatcoding was exactness.
thank for you help.
best regards
JBH.
Vladimir_Dudnik
Glad to hear you find a solution
Vladimir
