JPEG 2000 Code Stream
shawnf
I'm looking to decode JPEG 2000 code streams (into raw/bmp) using Microsoft.Net (C#).
Although I've found and compiled the "j2kit.exe" sample and it can do such conversions using files, I need to do this with in-memory streams and was hoping someone has maybe put together a JPEG2000 managed wrapper similar to the JPEG managed wrapper sample.
I realize I could use/port all of the C++ from the sample, but there is a LOT of code there and I was hoping Intel or someone here has already done this.
Shawn
Vladimir_Dudnik
Hello Shawn,
I would recommend you to take a look on JPEGView sample, which is able to decode JPEG2000 stream.
We do not provide C# interface to JPEG/JPEG2000 codecs in IPP 5.3. So you need to implement it by yourself.
Vladimir
