JPEG 2000 Decompression performance
Bj__246_rn_Andersson
I am currently working on JPEG2000 Decoder DLL, based on the Picnic application. For the picnic application i am achieving a decoding performance of 26ms per frame with a Dual core ~3GHz machine. I need to achieve a performance of about 13ms per frame. I am decoding 640*480 color jpeg2000 image files.
Question 1:
How can I optimize the Picnic application for better performance? What if I use precompiled UIC DLLs instead of adding the source files as in the Picnic project. Any suggestions?
Question 2:
I'm having trouble building the UIC dlls myself from the samples download, using build32.bat in \\Intel\\IPP\\6.1.2.041\\ia32\\Samples\\en_US\\ipp-samples\\image-codecs\\uic. I am getting these errors.
Start components compile
Building: Only UIC
******* uic_core PASSED
******* uic_io PASSED
******* uic_dss PASSED
******* uic_bmp PASSED
******* uic_pnm PASSED
******* uic_jpeg FAILED {see log file for details}
******* uic_jpeg2000 PASSED
******* ipp_zlib PASSED
******* uic_png FAILED {see log file for details}
******* uic_core_dotnet PASSED
******* uic_io_dotnet PASSED
******* uic_jpeg_dotnet FAILED {see log file for details}
******* uic_transcoder_con FAILED {see log file for details}
There were errors found
For example, in the log file for uic_transcoder_con I get this error " LINK : fatal error LNK1146: no argument specified with option '/LIBPATH:' "
Any ideas what is wrong?
Thomas_Jensen1
As for Jpeg2000 performance, there is a parameter that influences it:
param_jpeg2k.precision = J2K_16;
param_jpeg2k.precision = J2K_32;
J2K_16 is faster, and is okey for channels <=8 bit (such as 24 bit RGB).
If >8 bit is used (such as in 16 bit grayscale), J2K_32 must be used.
This is what I have deducted by testing, as Intel has no documentation for this parameter.
As for your building problem, I always make sure IPP_ROOT = the ia32 folder.
Thanks for the reply Thomas,
I will try the J2K_16 setting and see how it goes.
I'm not sure how to set the IPPROOT directory though. The readme says:
Set up your build environment by creating an environment variable named IPPROOT that points to the root directory of your Intel IPP installation.
Problem is I don't know what that means or how to do that.
Vladimir_Dudnik
On most of Windows system you can set up desired environment variable by right click on My Computer icon, choosing Properties from pop-up menu, select Advanced tab and click on Environemnt Variables button
Vladimir
Thomas_Jensen1
Yes, when I said IPP_ROOT (actually IPPROOT), I meant an environment variable.
Mine is set as follows:
IPPROOT = C:\Programs\Intel\IPP\6.1.5.054\ia32
Thanks guys,
Now i'm trying to decode a motion jpeg2000 stream. I get about 70 erronous frames out of 100 frames, which is way too much. Using another decoder its about 1% errors. The JPEG2000Decoder::ReadData returns an the error. I have saved two frames, one that failed and one that succeeded, and i thought someone else could try them and see if they work for them. I've already tried with Picnic and it does the same as my application.
The image looks a bit strange since it is 4:2:2 planar YCbCr shown in interleaved RGB, but that does not matter.
Another thing. What does the AlignStep function in the samples and documentation pdf do?
Seems i was to quick to assume that the file is intact. Using another video, there are not many error frames.
I investigated the error and its when ReadData calls ReadNextTilePartHeader() the second time. Then it reads the second tile-part header.
// search next tile-part header (mostly theoretical protection
// from damage because tile-parts should follow inseparable
// in the current version of JPEG 2000 standard)
JP2Marker marker = ReadMarker(stream);
while (marker != SOT)
if(marker == EOC)
m_isNextTilePartExist = false;
return false;
unsigned int markerSize = ReadMarkerBodySize(stream);
m_diagnOutputPtr->Warning(DiagnDescrCT());
stream.Seek(markerSize); <-----This one throws an exception in OnLackOfData()
virtual void OnLackOfData()
throw DiagnDescrCT();
Since the file seems to be corrupt I will not try to look into this more unless someone here actually knows what is causing this.
