JPEG 2000 compression
jboaz123
I am trying to compress the attached file using picnic application with the following parameters:
Files of type:JP2 Format (*.jp2)
Lossless
WT53
Use MCT checked
when I load save result I get gray image.
Problem not occurwith lossy.
Please advice
10x
Thomas_Jensen1
I took a look at the dicom file. It is not properly structured:
Missing tag: SAMPLES_PER_PX (0028:0002)
It is bad to not indicate how many channels a pixel has.
Missing tag: PHOTOMETRIC (0028:0004)
It is bad to not indicate how the pixels are structured.
Also missing tag: PIXEL_SPACING (0028:0030), should indicate size of a pixel.
Further, Bits Stored = 14
The IPP Dicom decoder does not use two very important tags: BITS_STORED (0028:0101) and HIGH_BIT (0028:0102). The decoder assumes the image is 16 bit, and thus with 14 bits, the whitest pixel has value 2^14-1, which in 16 bit space is 1/4 of white, or, dark gray.
If you want to fix this problem, you must modify the IPP Dicom decoder to return tags Bits Stored and High Bit.
Using that, you can add code to Left_Shift all bits 16-HighBit (16-14 = 2 -> 14 bit becomes 16 bit).
Actually, although your Dicom file is 14 bit, only 11 bits are used, thus even when upscaling the specified 14 bit to the full 16 bit, that result will display as a very dark gray image. To fix that, you need to disregard the specified 14 bit and "detect" the actual number of bits (11), and then do the upscaling.
Intel could consider adding code to the Dicom decoder sample, to upscale the image from <16 bit (9..15 bit) to full 16 bit, when returning a 16 bit image. Motivation: The Dicom file specifies 14 bit, so 2^14-1 = white. Therefore in the context of the Dicom decoder, the 14 bits *must* be considered full range, and then, since it returns a 16 bit image, it must remap 14 bit white to 16 bit white.
Vladimir_Dudnik
Hi Thomas,
thanks for loking into problem, your comments looks reasonable. I think we will adopt DICOM parser according your advices.
Vladimir
jboaz123
I attached correct 8 bit DICOM file and the jpeg 2000 lossless compression result image Compredded.jp2.
You can notice the wrong result.
Sergey_Ryadno
Hi, jboaz123
I found reason of this problem. In case of Lossless mode for J2K image saving variableparam.quality always equal to 0. This bring to encoding image to zero size. To fix this issue you need to change one row in filesavedlg.cpp. In functionvoid FileSaveDialog::updateJpeg2000Buttons(void) change:
m_jpeg2000RatioSlider.setValue(0);tom_jpeg2000RatioSlider.setValue(100);
jboaz123
Hi, sryadno
Thank you for your advice, I will check it.
Thomas_Jensen1
I can confirm that saving Jpeg2000 Lossless 12 bit grayscale always gives a 1KB useless file, in UIC samples version 6.1.3.052.
Sergey_Ryadno
HiThomas,
the fix i described one post early remove this problem. i just test picnic with this changes on 12/16 bit grayscaleimage - and it works fine.
