JPEG encoding
aabusai1
I need to use intel IPP to jpeg compress raw data ? is that possible under IPP ? also any example
can help start implementing this ?
for the raw data I know the width and height and it's RGB.
Amr
Vladimir_Dudnik
I would recommend you to take a look at IPP sample package (which is separate download available from IPP main page). Within this sample package you will find a number of IPP image codecs, for example, JPEG compression is available through well known libjpeg API, old Intel JPEG library API and new UIC (unified image codecs) framework.
Vladimir
aabusai1
Vladimir
I used some of the code supplied from the sample,now I can jpeg compress the raw input but the produced image has
wrong color (it consists of one color) while the original has RGB color.
any idea of what's going on ?
I used setsource ,setsparam,setDestination,writeheader and writedata) methods from jpegenf file..
thanks
Amr
Vladimir_Dudnik
I think it also important how do you use all these setSource, SetParams, SetDestination.. Having no look at this it is difficult to get any idea of what is going wrong.
Vladimir
