JPEG lossless DeCoding problem
senmeganath
I'm currently running into problems while decoding some 16/12 bit jpg lossless grayscale pictures to bmp using code from the UIC example
My code is working for fine for all 8 bit images. but its failing for 12/16 bit JPEG lossless images.
Picture information:
witdh = 990
height = 24950
bits per pixel = 16 bit
number of planes = 1
Do you have any idea what is happening here? I think that every value should be valid as source pixel when decoding JPEG lossless.
I've attached the Compressed & decompressed imageData. please do the needful.
Senthil.
Chao_Y_Intel
Hi Senthil,
Have you tried uic_transcoder_con application in the UIC sample?This sample application may provide you some example on using the UIC.
Chao
senmeganath
Quoting - Chao Yu (Intel)
Hi Senthil,
Chao
Hi Chao Yu,
Yes, I am using uic_transcoder_con application sample code. but its working fine for 8 precision images but its failing 12/16 precision images.
senmeganath
Quoting - senmeganath
Hi Chao Yu,
Hi Chao Yu,
Either i reduced bits from 16/12 to 8, and then will use JPEGDecoder. or any other way to Decode. please guide me.
senmeganath
Hi Chao Yu,
Hi Chao Yu,
My problem getting solved using the "reducedBits" method.
once decode a 16/12 bit image, we need to reduce the bits to 8. thanks for ur help.
Chao_Y_Intel
thanks for sharing in forum, senmeganath.
