Java Interface?
nathanm
Some samples (apparently older ones) had an example of a Java interface. They would not compile - missing ippcp.h.
I installed the samples that correspond to the latest IPP version 6.1.1.035 - and they did not have any examples of a java interface. Is this no longer supported?
For my needs, I would need a java interface
OR
a simple command line interface would do.
I simply want to resample jpegs using an interpolation filter - I know IPP can do much more than that.
Nathan
Ying_S_Intel
Quoting - nathanm
OR
Nathan
Nathan,
First, the Java sample is located in ipp-sampleslanguage-interfacejava if you download the Intel IPP sample for Windows* in v6.1.
There are few changes in Intel IPP samples in the latest IPP sample v6.1 based, please go to our knowledge base at: http://software.intel.com/en-us/articles/sample-changes-in-intel-ipp/ for more details.
Secondly, if you notice the missing ippcp.h file, please check if you have the Intel IPP cryptography libraires installed. It is a sperate library install due to U.S. export control requirements, please refer our recent posting at:
http://software.intel.com/en-us/forums/showthread.php?t=67023 for reference or add your comments there.
Ying
nathanm
Quoting - Ying S (Intel)
Nathan,
Ying
Yes, I do need the Cryptography libraries.
But I don't think I'll be able to get them till you fix the premier support web page.
It keeps redirecting to here:
https://welcome.intel.com/scripts-util/500.asp?aspxerrorpath=/Login.aspx
Nathan
nathanm
Well. Ive gotten the crypto libraries but I still can't compile the example.
I'm a bit frustrated with having to reverse engineer the build scripts.The Readme says "Edit the build32.bat file to make sure it sets the appropriate environment for the desired build tools". I wish it would say more about setting what environment variables to what so I wouldn't just keep guesssing.I'm running it from a VS 200 command prompt and trying to use that as the compiler.
Can anyone who has gotten this example to work offer suggestions?
Below is as far as I've gotten.
cl /nologo -I"C:Program FilesJavajdk1.6.0_13"include -I"C:Program F
ilesJavajdk1.6.0_13"includewin32 -I"C:Program FilesIntelIPP6.1.1.035ia3
2"include -I"srcnativewin32_IA" /EHsc /w /O2 -LD objwin32_IAjipp_dc.obj "C
:Program FilesIntelIPP6.1.1.035ia32"stublibippdc.lib -Felibwin32_IAjipp
dc.dll
Creating library libwin32_IAjippdc.lib and object libwin32_IAjippdc.exp
2"include -I"srcnativewin32_IA" /EHsc /w /O2 /c /Foobjwin32_IAjipp_core.ob
j srcnativejipp_core.c
jipp_core.c
2"include -I"srcnativewin32_IA" /EHsc /w /O2 -LD objwin32_IAjipp_core.obj
"C:Program FilesIntelIPP6.1.1.035ia32"stublibippcore.lib -Felibwin32_IA
jippcore.dll
Creating library libwin32_IAjippcore.lib and object libwin32_IAjippcore.e
xp
The system cannot find the path specified.
C:Samplesipp-sampleslanguage-interfacejava>endlocal
C:Samplesipp-sampleslanguage-interfacejava>GOTO:EOF
Ying_S_Intel
Quoting - nathanm
dc.dll
jipp_core.c
jippcore.dll
xp
It seemed a path problem, by default, the sample will be installed under directory C:Program FilesIntelIPP6.1.1.035 where you installed the Intel IPP libraires. So you may need to modfiy the make file from this Java sample to point out your sample installation folder.
Ying S
