Linking problem on x86_64 Android with static libraries
Agmon__Morag
Hi
I am getting a linker error when I try to build a shared library with static linking of the Android IPP libraries for x86_64 (intel64):
Android/Sdk/ndk-bundle/build//../toolchains/x86_64-4.9/prebuilt/windows-x86_64/lib/gcc/x86_64-linux-android/4.9.x/../../../../x86_
64-linux-android/bin\ld: error: libipps.a(pscosm7l9as_y8.o): requires dynamic R_X86_64_PC32 reloc against 'y8_ownsCosOne_m7y8' w
hich may overflow at runtime; recompile with -fPIC
Same build for x86 (32-bit) works just fine.
Any hint ?
Igor_A_Intel
Hi Morag,
the code freeze and final build for upd#2 was significantly earlier than you had submitted the bug. It is fixed in 2018 upd#3 and 2019 gold, upd#3 will be available on the web somewhere on/after ww22.3 (May, 30).
regards, Igor
Chao_Y_Intel
Morag,  which IPP version are you using?  We notice one issue in 2017 release, but it was fixed in the IPP 2017 package.
Chao
Agmon__Morag
Hello Chao
I am using the latest release, 2018.1.163 .
Morag
Agmon__Morag
Hi Chao,
Can you confirm that the issue can be reproduced on your side, and is going to be addressed ?
Morag
Igor_A_Intel
Hi Morag,
you are right, several internal symbols in IPP (libipps.a) have wrong ".global" attribute that lead to the issue you've faced with:
000000000a51  000800000002 R_X86_64_PC32     0000000000000000 y8_ownsCosOne_m7y8 - 4
0000000010e1  001900000002 R_X86_64_PC32     0000000000000000 y8_ownsExpOne_m7 - 4
0000000010e6  001a00000002 R_X86_64_PC32     0000000000000700 y8_ownsExpOneF_m7 - 4
000000000dd1  002700000002 R_X86_64_PC32     0000000000000000 y8_ownsPowOneF_m7 - 4
000000004111  003f00000002 R_X86_64_PC32     0000000000000000 y8_ownsPowOne_m7 - 4
000000000a81  000900000002 R_X86_64_PC32     0000000000000000 y8_ownsSinOne_m7y8 - 4
000000001951  000900000002 R_X86_64_PC32     0000000000000000 y8_ownsTanOne_m7 - 4
already fixed, the fixed libs will be available in the nearest future in the further IPP releases/updates.
regards, Igor
Agmon__Morag
Hi Igor,
Thank you.
We are looking forward for that.
Please do, as always, document these fixes in the release notes.
Morag
Agmon__Morag
Hi
Issue still exists in 2018.2.199 (2018 Update 2).
In which version can you commit for a fix ?
BR,
Morag
Igor_A_Intel
Hi Morag,
regards, Igor
Agmon__Morag
Hi Igor,
Thank you for the information. We are looking forward that.
Br,
Morag
Agmon__Morag
Hi
Confirm that issue is resolved with v2018.3
Igor_A_Intel
Thanks for notification,
Regards, Igor
