6847 Discussions
Linux Application Debugger for 32-bit applications, Version 7.3.1
shimul
I have the problem during the installtion of debugger see below.
please help me.
Where do you want to install to? Specify directory starting with '/'. [/opt/intel_idb_73]
/opt/intel_idb_73
What rpm install options would you like? [-U --replacefiles]
-U --replacefiles
--------------------------------------------------------------------------------Linux Application Debugger for 32-bit applications, Version 7.3.1
Installing...
error: Failed dependencies:
libstdc++-libc6.2-2.so.3 is needed by intel-iidb7-7.3.1-87
Installation failed.
Press Enter to continue.
Vladimir_Dudnik
I believe this debugger is part of Intel C/C++ compiler package? If so, it is better to ask this question on compiler forum.
By the way, as I can see, libstdc++-libc6.2-2.so.3 is missed, so you should find and install appropriate rpm package.
Vladimir
