6845 Discussions
Linux link error: undefined reference to ippMalloc/ippFree
piet_de_weer
I've just converted an application from Windows (MSVC, Intel compiler, IPP) to Linux (gcc - for now at least, IPP).
When I try to build it, I get 2 errors:
[bash]/opt/intel/ipp/6.1.2.051/ia32/lib//libippsmerged.a(psalloc_split_w7_ippsMalloc_8u.o): In function `w7_ippsMalloc_8u':
psalloc_split_w7_ippsMalloc_8u.i:(.text+0x17): undefined reference to `ippMalloc'
/opt/intel/ipp/6.1.2.051/ia32/lib//libippsmerged.a(psalloc_split_w7_ippsFree.o): In function `w7_ippsFree':
psalloc_split_w7_ippsFree.i:(.text+0x12): undefined reference to `ippFree'
collect2: ld returned 1 exit status
[/bash]
The other IPP functions that I'm using don't seem to cause any issues. I'm building using the following line:
g++ -v -O3 -ffast-math -fomit-frame-pointer -fstrict-aliasing -fno-math-errno -freciprocal-math -fno-signed-zeros -fno-trapping-math -fassociative-math -DSSE2 -I/opt/intel/ipp/6.1.2.051/ia32/include/ -L"/opt/intel/ipp/6.1.2.051/ia32/lib/" -march=pentium4 -lippcore -lippscmerged -lippsrmerged -lippsmerged -lm
In Windows, building with the following (very similar) line succeeds and generates working code:
g++ -v -O3 -ffast-math -fomit-frame-pointer -fstrict-aliasing -fno-math-errno -freciprocal-math -fno-signed-zeros -fno-trapping-math -fassociative-math -DSSE2 -I"C:\\Program Files 2\\Intel\\IPP\\5.1\\ia32\\include" -L"C:\\Program Files 2\\Intel\\IPP\\5.1\\ia32\\lib" -march=pentium4 -lippcorel -lippscmerged -lippsrmerged -lippsmerged -lm -lwinmm
What am I missing?
Note: This is a build which ONLY includes the Pentium 4 code - I haven't tested what happens if I don't specifically include the file ipp_w7.h because I need to make changes at different locations in the code.
Naveen_G_Intel
There is good discussion and provided solution for similar issues in the forum, please refer to Linux Port - Linker problems
Also, On-line documentation: how to build ipp in linux environment
http://software.intel.com/en-us/articles/how-to-build-ipp-application-in-linux-environment/
Naveen Gv
piet_de_weer
Thanks! Moving -lippcore to the end of the line did the trick. And the program is even running immediately without any errors (which is quite surprising for a program that consists of over 2 MB of code).
Naveen_G_Intel
Great to know it works fine,
Naveen Gv
