Loading C# app with IPP
Sharper
Hello All,
I would really appriciate your help here. I am new to IPP 7.0 .
I have downloaded the evaluation of IPP and trying to run a sample application that
was delivered by intel package. The project "wavelet".
When the application start to run and try open an image file and resize it
with the function "ippiResize_8u_C3R" .. I am getting the error :
"An attempt was made to load a program with an incorrect format. (Exception
from HRESULT:0x8007000B".
Please I am running on google to find a solution for more then 3 days....
Thanks in advance
Eyal
Ying_H_Intel
Hi Eyal,
We can't reproduce your probelm here.No sure your exact enviorment, but it may be helpful to set IPP run-time environment variable before you run the program.
If you have thewavelet.exe produced. Would you please tryit in command line
for example
>C:\Users\yhu5\Desktop\IPP7.0\w_ipp-samples_p_7.0.4.054\ipp-samples\language-int
rface\csharp\bin>"C:\Program Files (x86)\Intel\ComposerXE-2011\ipp\bin\ippvars.
at" ia32
rface\csharp\bin>wavelet.exe
The application should be able to open the jpgfile in the smaple folder : csharp\application\wavelet\data automactially. You can try to openother image too.
And in Visual studio, the resultis like below
Ying .
