MPEG-2 Decoder Sample
wallace
I can't get the MPEG-2 Decoder sample to render anything. I've tried TransportStream and ProgramStream wrapped media. Should the TransportStream packetized media work?
Does anyone have any media that works with this sample?
ids-removed222
you can get samples at www.mpeg.org
otherwise, I have another question :
can mpeg2 decoder support MP@HP , MP@MP profile and level ?
any samples also ?
thank you very much !
Vladimir_Dudnik
could you submit your issue through technical support channel? If you can share one bitstream which cause your problem it will help us to investigate this case.
Vladimir
Vladimir_Dudnik
IPP MPEG2 decoder sample does support MP@HP , MP@MP. Please report us in case you find any problems with that.
Vladimir
