MPEG-4 Linker error with static libs
ahmadkq
I tried to compile my project under VC++6. I got the following linker errors:
ippvcmerged.lib(pvcmcown_split0.obj) : error LNK2001: unresolved external symbol ___security_cookie
ippvcmerged.lib(pvcmcown_split1.obj) : error LNK2001: unresolved external symbol ___security_cookie
ippvcmerged.lib(pvcmc_split0.obj) : error LNK2001: unresolved external symbol ___security_cookie
ippvcmerged.lib(pvcmc_split2.obj) : error LNK2001: unresolved external symbol ___security_cookie
ippimerged.lib(pidct88i_3_split10.obj) : error LNK2001: unresolved external symbol ___security_cookie
ippvcmerged.lib(pvcmcown_split0.obj) : error LNK2001: unresolved external symbol @__security_check_cookie@4
ippvcmerged.lib(pvcmcown_split1.obj) : error LNK2001: unresolved external symbol @__security_check_cookie@4
ippvcmerged.lib(pvcmc_split0.obj) : error LNK2001: unresolved external symbol @__security_check_cookie@4
ippvcmerged.lib(pvcmc_split2.obj) : error LNK2001: unresolved external symbol @__security_check_cookie@4
ippimerged.lib(pidct88i_3_split10.obj) : error LNK2001: unresolved external symbol @__security_check_cookie@4
Do you have any idea to fix this problem?
thanks alot,
Vladimir_Dudnik
regarding media sample's ReleaseNotes.htm file we do not support VC6.0. But actually it is known issue, you can work it around by linking bufferoverflowu.lib taken from MS Platform SDK. The reason is that IPP 5.x was compiled to be compatible with MS compiler /GS option (enable security checks) available in MS VC .NET2003 and this option is not compatible with older MS compilers.
Compiler
Option
Intel C++ Compiler 9.1 for Windows* icl91
Intel C++ Compiler 9 for Windows* icl9
Intel C++ Compiler 8 for Windows* icl8
Microsoft* Visual C++*.NET* 2005
(Only for IA-32 based systems)
cl8
(only with build32.bat)
Microsoft* Visual C++*.NET* 2003 cl7
Vladimir
ahmadkq
Thanks alot
Vladimir_Dudnik
you are welcome:)
