MPEG-4 video coding in IPP
Tamer_Assad
Innovator
MPEG-4 part 2 uses H.263 video coding
MPEG-4 part 10 uses H.264 video coding
IPP provides H.263 and H.264 Encoder/Decoder, also an MPEG-4 Encoder/Decoder.
I wonder:
1) Which video coding is used by IPP MPEG-4 Encoder/Decoder, as I understand it is an ITU standard with sub
standards/parts?
2) if it is H.263 or H.264, how is it compared to the existing IPP H.26x?
Tamer
Vladimir_Dudnik
Hi Tamer,
if you pay attention to IPP audio-video-codecs documentation (namely, readme.htm files in codecmpeg4-enc folder) you may see that IPP MPEG4 encoder implements:
The encoder supports the standard ISO/IEC 14496-2 with certain restrictions. Only the following features are supported in the current version:
  • I-VOP
  • P-VOP
  • B-VOP
  • S-VOP
  • AC/DC Prediction
  • 4MV
  • Un-restricted MV
  • P-VOP with OBMC
  • Quantisation Method 1,2
  • Videopackets
  • Short video header
  • Data partitioning
  • Reversible VLC
  • Interlacing
  • Basic sprites
  • Quarter-Pixel Motion Estimation
  • Global Motion Estimation (Number of Warping Points 0 an 1)
  • VBR and CBR Control
Vladimir
Tamer_Assad
Innovator
Hi Vladimir,
Thank you for your response.
Im bit confused, isnt ISO/IEC 14496-2 is the same as the MPEG-4 part 2 (H.263) ?
Tamer
Vladimir_Dudnik
Hi Tamer,
The ISO/IEC 14496 part 2 specification defines several video coding profiles. One of them is basic H.263 coding (it does not include the latest H.263 annexes).
Vladimir
