6827 Discussions
MPEG muxer/demuxer custom elementary stream support
Ali_Gökalp_P_
We are developing a publish /subscribe based application that streams video over a network environment.
But in this streaming data we use video and an elementary streaming that has a different format than audio elementary stream.
We've developed transport part but trying to replace it with IPP - UMC libraries.But before starting this process , we should assure that UMC fulfills project needs.
So , does UMC supports transporting video and private elementary stream?
Thanks...
Vladimir_Dudnik
sorry for delay, our expert was on vacation. So, his answer is
Of course, private elementary streams are supported.
Important thing is that muxer/demuxer should be able to evaluate the type of data carried inside elementary stream.
Streams of unknown type will be discarded.
Vladimir
Ali_Gökalp_P_
So how should we identify this private stream AUDIO_TRACK VIDEO_TRACK VBI_TRACK ? UNDEF_TRACK is discarded due to answer.And only we know the format of private stream ,UMC or IPP has any information about it.Should we write our handler to format data?
And sorry for delay , this private stream support problem has an affect on SU development part.We'll migrate our mux/demux to IPP only if IPP support user defined private streams.
Vladimir_Dudnik
Sorry for the delay, there is developr's comment:
VBI isnt fully supported by mpeg2mux although there is some code.
Vladimir
Ali_Gökalp_P_
What does developer mean by there is some code?
Vladimir_Dudnik
He mean that there is no complete workable solution yet. This is the reason why it was not released in IPP sample.
Vladimir
