MPEG1 Encoder Example
janlund1967
Hi.
Doessomeone have a MPEG1 encoder example in its simplest form?
(ie. no dectection of anything, hardcoded framesize, hardcoded frame rate etc)
Basically, i want to stuff a series of Ipp8u* 's (coming from a framegrabber) into a MPEG-1 file.
Something like this (pseudo C - i am a Delphi programmer :o) :
MyMP1Encoder->Init("C:Test.mpg");
For (x=0; x
{ MyMP1Encoder->AddFrame(MyNewFrame); }
MyMP1Encoder->DeInit;
Howshould i implement the Init, AddFrame and DeInit methods ?
Jan
Vladimir_Dudnik
Hi, why do you need in MPEG1? Probably you can also use MPEG2? If so, please take a look on IPP media sample, which contains video_ec_con application to demonstrate how to implement MPEG encoders with IPP and UMC
Vladimir
Vladimir_Dudnik
There is also comments from our MPEG expert
First, we dont support mpeg1 encoding, but do mpeg2. There is no significant difference.
To do encoding a simplest way it is needed to create an encoder object MPEG2VideoEncoder, then create VideoEncoderParams, set there width, height, frame and bit rate.
Then call encoder->Init(params).
After that create VideoData for input and MediaData for output. Than in loop read uncompressed YUV video to VideoData, call encoder->GetFrame, and store MediaData.
Deletre created objects. That is all.
umc_video_enc_con can be used as an example and for more information. Documentation to UMC and components is available as well.
Vladimir
