6847 Discussions
MPEG2TS file made using umc_samplecode(umc_mpeg2_muxer) will not play properly
SeongRyong_B_
Hello
MPEG2 Muxer for using IPP development.
By using UMC SampleCode Muxing H264 VideoStream MPEG2TS File to save the hayeotneunde,
This file is to be played in a particular Player, Elecard Analyzer opened in case, PAT, PMT and all information will be properly analyzed.
However, when opened in VLC or Elecard StreamEye, "Unsupported format" called out.
VideoStream MPEG2TS Tool to extract only the case make it, finishing the analysis typically H264 files, StreamEye also in the normal operation.
Muxing a file attachment with the table here, thank you dambyeon.
Thank you.
SeongRyong_B_
Answer Please.....................
