MS RT-Audio Codec in IPP 6.0
kevino
I noticed that the sample applications in IPP 6.0 for Windows make use of a Microsoft RT library (ipp_rta.lib) for which there is no source code our documentation. Is this file redistributable, or do I need to get it from Microsoft?
Vyacheslav_Baranniko
New Contributor II
It is only redistributable under terms covered byIPP EULA.
Slava
kevino
Slava
And what about RT-Audio under Linux? Is there a redistibutable for that, or is it simply not supported under Linux?
kevino
Is there a source code example for the RT-Audio codec?
New Contributor II
New Contributor II
IPPfunctions for RTA are availableon each platform which supported by IPP.Microsoft RT Audio APIissupportedin Windows only and there is no plan to support it in Linux. Meanwhile, USC interface for IPP RTA codecin Linux is under consideration.
New Contributor II
IPP does not plan to releaseRT Audio codec in source.
New Contributor II
IPP60 releasesin source sample supportingRT Audio codec in Windows based on ipp_rta.lib.
