6844 Discussions
Memory Leak problem for Intel Jpeg Compression
danielwang1971
I tried new IPP version 5.3. I found memory leakissue for Intel JPEG Library.
This issue onlyhappen BASELINE mode.
I modify function OnSaveAs of JPGViewView like:
void
CJPGViewView::OnSaveAs(void)
CString fname;
for(int i = 1; i< 100; i++)
fname.Format(_T("c:\Test\ttt%d.jpg"),i);
pDoc->SetParamsJPEG(JPEG_BASELINE,75,0,JS_444,JC_GRAY,0);
pDoc->OnSaveDocument(fname);
return;
And then run JPGViewView to save image.
The sample BMP is attached, Can you tell me what's problem?
Daniel wang
Vladimir_Dudnik
it is not clear do you see memory leak on original sample's code or on your modified version?
Vladimir
danielwang1971
Hello Vladimir,
Isee memory leak in both.
Daniel wang
Vladimir_Dudnik
Ok, we need to check. Therewere no such known bug detected by our testing.
Vladimir
Vladimir_Dudnik
we still were not able to reproduce your issue, Could you please provide simple test case and specify how do you exactly see that memory leak?
Vladimir
