Memory leak in MPEG2VideoDecoderBase?
dewildt
I think I found a small memory leak in MPEG2VideoDecoderBase:
In the beginning MPEG2VideoDecoderBase::Init() will call BaseCodec::Init().
If the initialization parameter of BaseCodecParams->lpMemoryAllocator is set to NULL, then BaseCodec::Init() will create an own instance of DefaultMemoryAllocator for m_pMemoryAllocator and m_bOwnAllocator is set to true.
In the further processing of MPEG2VideoDecoderBase::Init() the method Reset() is called which will set m_bOwnAllocator to false.
The result is that m_pMemoryAllocator will never be freed.
regards,
Daniel
Vladimir_Dudnik
Thanks Daniel,
I'll forward this info to ourdevelopers. By the way what version of IPP do you use? Is that the latest IPP 5.3 release?
Vladimir
Leonid_K_Intel
It really happened and was fixed before IPP 5.2 gold.
Leonid
dewildt
I'm using the IPP-samples 5.3.083 (but that part of the code identical to that of version 5.3.095)
