Merging 2 images
trlinux
Hi there,
I have 2 images with alpha channels, one of them alpha value is equal to 255 and the other 128 booth of them same size, let me know how can i merge these images together. I wanna place transparent image on to full visible image(like background). Is there any easy way or ipp function for this ? Thanks ...
Naveen_G_Intel
Probably ippiAlphaCompC function will match your requirement. This function is basically combines two images using constant alpha values.
Please refer to ippidemo.exe inside the IPP installation folder. Open an image, then select Process->Process by -> Logical& Alpha comp->Alpha Composition, then setect ippiAlphaCompC function and second image.
To get more information about this function refer to - http://software.intel.com/sites/products/documentation/hpc/ipp/ippi/ippi_ch5/functn_AlphaCompC.html
Naveen Gv
Naveen_G_Intel
Naveen Gv
trlinux
This is exactly , what i was looking for ... Thanks a lot sir ...
marrisa
HI there
I have  encountered the same problem.I have tried to merge the image using this code which is from google:
namespace WindowsApplication1
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        public static string FolderName = "c:/";
        private void button1_Click(object sender, EventArgs e)
            string fileName1 = FolderName + "Sample1.tif";
            string fileName2 = FolderName + "Sample2.tif";
            string fileNameMerged = FolderName + "Merged.tif";
            REDocument doc1 = REFile.OpenDocumentFile(fileName1, new TIFDecoder());//use TIFDecoder open one tif file
            REDocument doc2 = REFile.OpenDocumentFile(fileName2, new TIFDecoder());//use TIFDecoder open another tif file
            BaseDocument docMerged = doc1.MergeDocument(doc2);//merge tiff image
            REFile.SaveDocumentFile((REDocument)docMerged, fileNameMerged, new TIFEncoder());//save new tif
But it display nothing.What's wrong with my code?I know there are many third  party program for image processing.So is there any powerful image program which supports to merge image directly.Thanks for any suggestion.
Igor_A_Intel
Hi Marrisa,
your question is not related to IPP, guess it's for another forum...
regards, Igor
Daniel_F_2
This Image Processing Library integrates mature and reliable functions for developers to merge images. You are capable of merging two or more image files into one.
