Merging JPEG images
jfhebert
I am using IPP 5.0 with CJPEGEncoder and CJPEGDecoder classes.
Does someone know if it is possible with IPP to merge (or join, or concatenate...) two JPEG images into one larger JPEG image? (without having to uncompress and recompress the data.)
JF
Vladimir_Dudnik
what do you mean under merging of two images? If you need just concatenate two binary files you can use comand "copy /B fileA.bin + /B fileB.bin fileC.bin". It will combine fileA with fileB and store merged file in fileC.
If you want to merge content of two images you need to decompress images combine them and after that compressthis new image.
Vladimir
jfhebert
Thanks for your answer.
I want to merge the content of two images. I could use two memcpy to do that, but the resulting binary file won't be a JPEG image, and I would need to have a Readerapplication to read and decode the merged image.
I will have to think about something else... (I don't have time to uncompress and recompress...)
Thanks anyway
JF
Vladimir_Dudnik
You have to at least decompress to quantized DCT coefficients (means to do huffman decoding). Otherwise - no way to do that.
Vladimir
