Missing MotionJPEG2000_dec.lib
Genady_Malinsky
I am used Intel IPP version 6.0.167 שמג I upgraded to the Intel IPP Composer XE 2011 SP1 and ipp-samples_p_7.0.7.064. My machin OS in Win7  32-bit my DirectX version is 11. I compile it with this command:
C:\IPP\\ipp-samples\tools>buildall.bat ia32 "cl8"
I got the following resualts:
Arch: ia32
Compilers: cl8
** "C:\IPP\ipp-samples\advanced-usage\cpuinfo\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\advanced-usage\ippsdrv\ippsapp\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\advanced-usage\linkage\customdll\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\advanced-usage\linkage\i_malloc\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\audio-video-codecs\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\data-compression\ipp_compress\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-codecs\ijg\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-codecs\uic\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\2d-wavelet-transform\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\3dmath\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\Face_Detection\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\image-processing-functions\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\image-processing-mfc\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\image-processing-templates\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\image-tiling\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\image-processing\ipl-ipp\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\language-interface\cpp\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\language-interface\csharp\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\language-interface\java\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\realistic-rendering\3d-viewer\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\realistic-rendering\ray-tracing\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\signal-processing\signal-processing-functions\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\signal-processing\signal-processing-mfc\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\signal-processing\viterbi\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\speech-codecs\"
**** cl8 [ OK ]
** "C:\IPP\ipp-samples\string-processing\ippgrep\"
**** cl8 [ OK ]
When I tested all the libs that created I notice the MotionJPEG2000_dec.lib is miising.
I need it to finish the upgrading can someone assit?
Regards.
