Missing libsvml.a
Dettlaff__Dawid
For the project I currently work  I need access to lisvml.a for Linux 64-bit architecture. Unfortunetly  I can find this lib in  <ipp directory>/lib or <intel compiler directory>/lib folders as suggested in this link https://software.intel.com/en-us/ipp-dev-guide-linking-options .
I would be grateful if you provide or indicate from where I can download this lib.
Dawid
Gennady_F_Intel
libsmvl is the Intel C Compiler runtime library and can find these libraries in <ipp directory>/lib or <intel compiler directory>/lib folders.
You should add a link to these libraries into your project or just source compilervars.sh intel64
( e.x - see into  this directory  /opt/intel/compilers_and_libraries_2019.2.187/linux/bin/ )
Dettlaff__Dawid
Unfortunetly  I can't find this lib in  <ipp directory>/lib or <intel compiler directory>/lib folders as suggested in this link https://software.intel.com/en-us/ipp-dev-guide-linking-options . I can't find also in /opt/intel/compilers_and_libraries_2019.2.187/linux/bin/
Gennady_F_Intel
pls take a look into  /opt/intel/compilers_and_libraries_2019.2.187/linux/compiler/lib/intel64 directory
the directory /opt/intel/compilers_and_libraries_2019.2.187/linux/bin  contains compilervars.sh script which will help you to set the needed environment variables...
