Multi-Channel Thresholding
thevisionguy
The IPPi multi-channel thresholding functions don't seem to do as they are documented. It appears they threshold independently on each channel, i.e. the comparison of each channel is not 'ANDed'.
Is this specific to v4.0 ?
Gary
Vladimir_Dudnik
Hi Gary,
yes, you are right, IPP functions do thresholding independently for each channel. If you found that in documentation described different behaviour it is mistake in documentation, you can submit it to premier.intel.com, so we will correct description.
Vladimir
