Need help downloading the IPP cryptographic lib
bitsmaker
I am using Intel IPP 7.0.6.300 x64. I cannot use the latest version of the IPP cryptographic libs as it complains about the version during the install. Which version of the IPP crypto lib can I use and where do I download it from?
Ying_H_Intel
Hello Bitsmaker,
The versionw_ccompxe_crypto_ipp_7.0.6.300.zip is matching IPP 7.0.6.300.
Could you please check if you have the product in your download listor
applyitbyhttp://software.intel.com/en-us/articles/download-ipp-cryptography-libraries/
or upgrade the IPP packgage to w_ipp_7.0.7.325.exe and it's corrsponding crypto package is
w_ccompxe_crypto_ipp_7.0.7.325.zip
The key point of installing IPP and IPP cryptographic library is that IPP main package and IPP Cryptographic package have exact version information matched.
Ying
bitsmaker
Thanks for the prompt reply but I cannot seem to find the 7.0.6.300 version of the crypto libs. The only version numbers I see are
7.344
7.325
6.278
5.258
4.221
4.196
3
2
1a
1
Unfortunately I cannot upgrade right away, hence the need for the 7.0.6.300 libs.
Thanks again
Ying_H_Intel
Hi bitsmaker,
I checked your accountwith our adminstrator, they mentioned if youcan see IPP 7.0.6.278. so, once youhas access to 7.0.6,you should be able to see 6.300 too. Could you please check the download list again
Or use IPP main package, 7.0.6.278?
Ying
bitsmaker
Hi Ying,
I found it. Thanks, you can close this issue.
Ying_H_Intel
Glad to know the news.
Ying
