Packed vs extended complex format?
lkeene
Hello, I have a quick question regarding the RCPack2D format and extended complex format. I'd like to normalize the result of an FFT by dividing it by its magnitude. Here's what I'm doing:
1) Compute forward FFT via "ippiFFTFwd_RToPack_32f_C1R". Store in "Result1_complexPacked".
2) Compute magnitude of above result via "ippiMagnitudePack_32f_C1R". Store in "Result2_real".
3) Normalize "Result1_complexPacked" by computing (Result1_complexPacked / Result2_real). To do this:
3a) Unpack "Result1_complexPacked" via "ippiPackToCplxExtend_32f32fc_C1R". Store in "Result1_unpacked".
3b) Loop through and normalize in-place:
for(int a = 0; a < Height; a++)
int denominatorRowOffset = (a * Width);
int numeratorRowOffset = (a * 2) * Width;
for(b = 0; b < Width; b++)
float denominator = *(Result2_real + denominatorRowOffset + b);
*(Result1_unpacked + numeratorRowOffset + (b * 2)) =*(Result1_unpacked + numeratorRowOffset + (b * 2)) / denominator; // Real component.
*(Result1_unpacked + numeratorRowOffset + (b * 2) + 1) =*(Result1_unpacked + numeratorRowOffset + (b * 2) + 1) / denominator; // Imaginary component.
3c) Repack "Result1_unpacked" for inverse FFT via "ippiCplxExtendToPack_32fc32f_C1R".
Is my understanding/usage of the Packed->Unpacked->Packed operations as illustrated above correct? It's the output ordering I'm unclear on.
-L
Chao_Y_Intel
This code looks fine. For step 3 ( 3a - 3c), possbilly it has some more efficient way:
It can divide the RCPack2D data by its magnitude according to RCPack2D format description in the manual. It does not need to convert to CplxExtend format, and then convert back.
Chao
