Problem in using G729
sivakrishna_a_
    We are using G729I speech codec, but problem is we have enabled VAD,NR everything, but audio is not proper, when we speak, there is some noisy like izzzzzzzzzzzzzz sound appears when we talk, so what needs to be set while encoding, is there any extra parameters required to set for clean audio. Plz help, as we have implemented it on behalf of AAC codec, needs to fix it.Plz suggest
Chuck_De_Sylva
Can you explain the specific IPP function(s) you are having issues with?
Thanks, Chuck
