Problem running samples
Sharper
I have problem running your "ipp_csharp" sample from the samples library.
When I am running the "wavelet" project - each time when there is a call to Ipp funtion,
for example : ippResize_8u_C3R , I get error "An attempt was made to load a program with
an incorrect foramt ( Exception from HRESULT: 0x8007000B )
Can you help me in solving this probelm. I am running trial version of IPP
and I would like to finish evaluate the package..
Thanks in advance
E
Chao_Y_Intel
The problem happened possilly because some project setting? I did a search. Is the following problem the same as yours?
http://stackoverflow.com/questions/2023766/an-attempt-was-made-to-load-a-program-with-an-incorrect-format-even-when-the-pl
Chao
