Problem with IPP_NR_EC
jmmsalvador
I can't open the output file of usc_nr aplication, and I would like insert parameter for noise reduction.
I can import raw data with Audacity
Naveen_G_Intel
Can you tell me how you have used noise reduction sample (usc_nr.exe) with this sample data?
As in the readme file should be used as usc_nr[options]
Naveen Gv
jmmsalvador
These are theparameters which i usein the program
-alg IPP_NR_EC D:\Garbage\Audio\input_file.wav D:\Garbage\Audio\IPP_NR_EC.wav
I getsomenoise reductionbut the resultsare not very good. Can I set the parameters of noise reduction?
Jose M
Naveen_G_Intel
Can you test with .PCM file?
Naveen Gv
Naveen_G_Intel
I have verified with .PCM files, it works fine.
Naveen Gv
