6845 Discussions
Problem with the IPP Data Compression running on a Quad Core processor
Rafael_de_Medeiros
I developed an applicationwhich use IPP Data Compression. The first code (which load the IPPDC library) is based on Delphi sample IPP Image Processing, available on IPP samples.
In this code, the ippdcGetLibVersion (ippiGetLibVersion on the sample)returns name = ippdcp8-6.0.dll+ if running at a Quad Core processor. Thisfile doesn t exist. I copy the ippdcp8-6.0.dll to ippdcp8-6.0.dll+ and it worked, but I need to know if this iscorrect.
Can you help me?
Rafael de Medeiros
Thomas_Jensen1
Are you sure you used stdcall on all IPP functions in Delphi?
Rafael_de_Medeiros
Yes. Iam sure.
function ippGetLibVersion: PIppLibraryVersion; stdcall;
The configuration is 2 Intel Xeon E5506 2,13GHz Quad Core and the function IPPGetCPUType returns decimal 37 (hex 25 - ippCpuNehalem)
Ying_H_Intel
I noticed you are calling IPP 6.0 dlls. How about try the latest IPP vesion: IPP 6.1 update 3?
You can downloadthe install package and sampleby following the instructionon http://software.intel.com/en-us/articles/ipp-downloads-registration-and-licensing/
Pleaselet us know if anyresult.
Yign
Rafael_de_Medeiros
Same problem with version 6.1. I emphasize that this problemoccurs only in this case.
This code is running in other 1000 clients without problem.
This is the sample of my code
result := LoadLibrary('ippdc-6.1.dll');
if (result <> 0) then begin
@tmpGetLibVersion := GetProcAddress(result,'ippdcGetLibVersion');
if (tmpGetLibVersion <> nil) then begin
version := tmpGetLibVersion;
loadedFullName := version.Name;
// In this point, the version.name = ippdcp8-6.1.dll+
FreeLibrary(Result);
Result := LoadLibrary(PChar(path + loadedFullName));
// Success
end else begin
loadedFullName := ComposeFullDllName(name, ipp_version);
// erro, load the old libray
end;
end;
end;
end;
Rafael
matthieu_darbois
New Contributor III
you don't have to unload ippdc-6.1.dll and try load ippdcp8-6.1.dll. Just go on with ippdc-6.1.dll
When you call functions in ippdc-6.1.dll, they are automatically mapped to the functions in the most suited DLL (in this case ippdcp8-6.1.dll)
You never have to worry about loading optimized DLL with IPP. You just load the dispatch DLL (the one with no xx extension). The rest of the work is already handled by Intel.
Matthieu
Rafael_de_Medeiros
Hi Matthieu, Thanks foryou reply.
I understand this, but why the Delphi sample at the IPPSamples (w_ipp-samples_p_6.0.0.117\ipp-samples\language-interface\delphi\src) do this?
Rafael
Vladimir_Dudnik
you do notneed to rename IPP files. The symbols '+' in string returned by ippdcGetLibVersion does not refer to file name. It is a notion that library may have tick-tock dispatcher in addition to traditional IPP dispatching mechanism.
Vladimir
matthieu_darbois
New Contributor III
As I don't use Delphi, I didn't see these samples. Why Intel is providing this like that ? Just loading the dispatch should be sufficient. Someone from Intel could clarify this point ?
Matthieu
Albert_Stepanov
When this sample was created there was only one dispatching mechanism. So '+' symbols in string were absent. And loading and unloading of libraries were developed in this sample to specify explicitly which processor-specific library should be loaded (Menu|Tools|Options...) and compare them performance.
Rafael, you can add following strings inyour code to remove symbols not relating to file name:
indx := Pos('+', loadedFullName);
Delete(loadedFullName, indx, Length(loadedFullName)+1-indx);
If anything you think I can help you, please feel free to tell me.
Albert
Chao_Y_Intel
For those who are using the sample, the fixed is includedin IPP 6.1 update 5 release.
Chao
