Procedure for applying the 5.3 runtime update
postaquestion
We recently purchased the IPP 5.3 Update. I want to redistibute IPP 5.3 but it appears that I have to continue to redistribute IPP 4.1 and then apply the 5.3 runtime update. Is this really the correct procedure? It seems that If I don't follow this procedure, the IPP 5.3 Update RTI does not install ippcore.dll.
What's the correct approach for redistributing 5.3?
Thanks!
Ying_S_Intel
Dear Customer,
Any reason that you need to redistribute Intel IPP 4.1still ?
You may check the redist.txt file from IPP root directory to find out the options you can choose from. Or a quick summary from http://support.intel.com/support/performancetools/libraries/ipp/sb/CS-027267.htm
Since Intel IPP 5.0, we no longer required the RTI as only option to distribute DLLs, you can also copy the required Intel IPP Dlls into your application destination folder.
Ying S
Intel Corp.
