Question about the HLS color mode
pango
I'm writing a color correct application,the app convert a RGB image to HLS format,and the adjust the H,L,S companents.I use IPP todo the converting,but I don't know the data format of the converted HLS image,I mean I don't know which byte is the H companent,and which is the L or S companent,and I also don't know the max & min value of each companent,so anyone can help me?
Vladimir_Dudnik
For ippiRGBToHLS_8u_C3R() we've written next:
H is the hue red at 0 degrees, which has range [0 .. 360 degrees],
L is the lightness , it has range [0. .. 1.],
S is the saturation, it has range [0. .. 1.]
H,L,S are scaled to the range:
[0..IPP_MAX_8u] for the 8u depth.
H = H * IPP_MAX_8U / 360.f;
L = L * IPP_MAX_8U;
S = S * IPP_MAX_8U;
To restore the true value(H,L,S) after ippiRGBToHLS_8u they should do next calculation:
H = (Ipp32f)H*360.f/(Ipp32f)IPP_MAX_8U;
L = (Ipp32f)L/(Ipp32f)IPP_MAX_8U;
S = (Ipp32f)S/(Ipp32f)IPP_MAX_8U;
Data is found in memory as an array of unsigned characters in which the first byte contains the H, the second byte contains the L, the third byte contains S.
P.S.: Please see ippiman.pdf for more details
Vladimir
