RGB image noise filtering with wiener filter
cashykbs_co_kr
I want to filter RGB noisy image (8u_C3) with wiener filter in IPP.
There are many sample codes of wiener filtering gray image. but I cann't find sample code for color image.
Sample Code below is wiener filtering in IPP manual.
In the sample code, there is no part for image border. There is no image border for filtering.
void func_wiener()
Ipp32f pSrc[256*256];
Ipp32f pDst[256*256];
int srcStep = 256*sizeof(Ipp32f);
int dstStep = 256*sizeof(Ipp32f);
IppiSize roiSize = {256, 256};
IppiSize dstRoiSize = {256, 256};
IppiSize maskSize = {3, 3};
int pBufferSize;
int channels = 1;
unsigned int pSeed = 3;
IppiPoint anchor = {1, 1};
Ipp32f noise[1] = {0.5};
ippiImageJaehne_32f_C1R(pSrc, srcStep, roiSize); // source image
//source image + RandUniform noise
ippiAddRandUniform_Direct_32f_C1IR(pSrc, srcStep, roiSize, 0, 1, &pSeed);
ippiFilterWienerGetBufferSize( dstRoiSize, maskSize, channels,
&pBufferSize);
Ipp8u* pBuffer = ippsMalloc_8u(pBufferSize);
ippiFilterWiener_32f_C1R( pSrc, srcStep, pDst, dstStep, dstRoiSize,
maskSize, anchor, noise, pBuffer);
ippsFree(pBuffer);
I write the code below... but the code is not working. Compling OK, But not working.
Could you tell me theerror of my code ?
IppiSize psize_4k;
psize_4k.height = 2160;
psize_4k.width = 3840;
IppiSize maskSize={3,3};
IppiPoint anchor={1,1};
Ipp32f noise[3] ={0.5};
Ipp8u *pimg_dst1 = (Ipp8u*)dst1->imageData;
Ipp8u *pimg_dst2 = (Ipp8u*)dst2->imageData;
ippiFilterWienerGetBufferSize(psize_4k, maskSize, 3, &pBufferSize);
Ipp8u *pBuffer = ippsMalloc_8u(pBufferSize);
ippiFilterWiener_8u_C3R(pimg_dst1, psize_4k.width*3, pimg_dst2, psize_4k.width*3, psize_4k, maskSize, anchor, noise, pBuffer);
ippsFree(pBuffer);
Vladimir_Dudnik
I would refer you to IPP documentation regarding Wiener filter, which include sample code. You need to pay attanetion that IPP functions required border values to be available in the memory. That means you need to build border around your image before apply IPP operation required border pixels.
Please also pay attention that step parameter for 3-channels images not always equivalent 3*width. It should take into account padding bytes which your memory buffer where you keep image may have. For example, BMP format requires image rows start from even address, this cause padding bytes at the end of row for some image sizes.
Vladimir
cashykbs_co_kr
Thank you for your reply.
But I can not find border for filtering in sample code of IPP manual.
Sample code for Wiener filter is as below. There is no image border for filtering.
I guess the function - 'ippiFilterWienerGetBufferSize' is tocalculate the momory size for image border.
Please reply !
void func_wiener()
int pBufferSize;
int channels = 1;
&pBufferSize);
ippsFree(pBuffer);
Vladimir_Dudnik
did you noticed IPP image-processing-functions sample where you may find call of wiener filter with color images?
Vladimir
