RandUniform issue
Isaac_D_
I'm trying to use the function ippsRandUniform_Direct_64f, but I can't obtain anything, I just get a vector full of zeros. Here is the function I'm using, maybe there's something wrong with the code. Hope you'll help me.
#include "stdafx.h"
#include "ipp.h"
#pragma warning (disable:4996)
static unsigned int *pSeed;
extern "C"{
_declspec(dllexport) void nnlsbp_1D(double u[]);
_declspec(dllexport) void nnlsbp_1D(double u[]){
    ippsRandUniform_Direct_64f(u,91,0,1,pSeed);
Gennady_F_Intel
how about pSeed value?
Igor_A_Intel
Hi Isaac,
first of all I reccomend you to use correct syntax while calling IPP - to use IppStatus and check it after a call - guess for this particular example you'll get     ippStsNullPtrErr            = -8,    /* Null pointer error. */ as pSeed pointer is not initialized...
regards, Igor
