Receiving MPEG4 stream from a IP camera?
bangjun_lei
Dear Sir./Madam,
We are experimenting of receiving MPEG4 video stream from a IP camera (Linksys WVC54GC). For this purpose we wrote our own data reader DataReaderHttp that can receiving data from the http server (provided by that camera). Then we do the following:
UMC::DataReaderHttp m_dataSrc;
UMC::DataReaderHttpParams m_dataSrcParams;
UMC::MP4Splitter m_videoSplitter;
UMC::SplitterInfo* m_pVideoSplitterInfo;
UMC::SplitterParams m_videoSplitterParams;
UMC::MPEG4VideoDecoder m_videoDecoder;
UMC::VideoDecoderParams m_videoDecoderParams;
UMC::VideoData m_videoInRaw;
UMC::MediaData m_videoInCompressed;
// Initialize data reader component
m_dataSrcParams.m_strPath = m_strPath;
m_dataSrcParams.m_camPort = m_camPort;
m_dataSrcParams.m_bAuthenticationNeeded = m_bAuthenticationNeeded;
m_dataSrcParams.m_strUsername = m_strUsername;
m_dataSrcParams.m_strPassword = m_strPassword;
if(m_dataSrc.Init(&m_dataSrcParams)!=UMC::UMC_OK)
ReportError(_T("The video source is not available!"));
return E_FAIL;
// Initialize splitter component
m_videoSplitterParams.m_lFlags = UMC::VIDEO_SPLITTER; // Want to extract only video
m_videoSplitterParams.m_pDataReader = &m_dataSrc;
if(m_videoSplitter.Init(m_videoSplitterParams)!=UMC::UMC_OK)
ReportError(_T("The video splitter is not available!"));
return E_FAIL;
The executing always get stucked at " if(m_videoSplitter.Init(m_videoSplitterParams)!=UMC::UMC_OK)".
Could you help to indicate to us how we can correctly do this kind of MPEG4 stream decoding?
Thank you very much!
Sergey_O_Intel1
Hello!
I believe that the problem is that your stream is not an MP4 container format. Spec of your cam says:
Wireless-G Internet Home Monitoring
Camera
Specifications
Model WVC54GCA
Standards IEEE 802.11g, IEEE 802.3, IEEE 802.3u
Ports Ethernet, Power
Buttons Reset
LEDs Power
Cabling Type Cat5
Number of Antennas 1 Internal
Connector Type N/A
Detachable Antenna No
UPnP able/cert UPnP Advertise
.Net Support N/A
Security Features WEP-64, WEP-128, WPA, WPA2
Image Sensor CMOS
Lens Fixed Focus
Resolution 640 x 480, 320 x 240, 160 x 128
Relative Illumination 5.1 Lux
Effective Focus 3 mm
Sensitivity 3.0V/Lux-sec
Field of View 61.48 degrees
Compression Algorithm MPEG-4 and MJPEG
Record File Format ASF
Brightness Auto/Manual Adjustment
So it seems that your stream is ASF container and not MP4 (See ISO 14496-12). Unfortunately there's no ASF splitter in UMC release yet.
-Sergey
bangjun_lei
Thanks!
But they do provide both asf and mp4 streams.
Sergey_O_Intel1
Please give me a piece of stream you get from your cam.
Concerning streaming UMC MP4 splitter can only split fragmented MP4 streams (see 14496-12)
bangjun_lei
Sergey, thanks! Please find attached one segment of the video stream!
Sergey_O_Intel1
Your stream is ASF stream with one MS MPEG-4 v3 video stream inside.
So you need ASF splitter anyway. I hope it will be present in the next version of UMC.
But unfortunately UMC mpeg4 decoder is unable to decode MS MPEG-4 v3. This standard is closed. Our decoder supports ISO mpeg4 video (ISO 14496-12) only.
Can you choose the output stream format in your cam?
bangjun_lei
Sergey,
Thank you very much for this!
Unfortunately I cannot change the video format. Strangely enough that I can use VLC to play the video stream. Do you know by chance how they did it?
Thanks again!
Sergey_O_Intel1
I failed to play your stream by VLC (Maybe you play streamingandI just opened your file)
Anyway closed standard only makes peopleuse theirdll to decode it.
