Rmoving the Alpha channel from an RGB
brian_barber
I have RGBs with an alpha channel to do some blending (using ippiAlphaComp_8u_AC4R). After the blending is done I need to convert the output rgb into yuv4:2:0. I don't care if I lose the alpha channel during this process.
Currently, I'm removing the alpha channel by walking through the RGB and copying only the RGB into a new buffer. There must be a better way.
Vladimir_Dudnik
you can consider to useIPP functions like ippiBGRToYCbCr411_8u_AC4P3R or ippiBGRToYCbCr420_8u_AC4P3R
Vladimir
brian_barber
Thanks for the response.
I guess I'm not 100% sure. I need the image to be in YUV420 format so I've been using calls like ippiRGBToYUV420. Is there much of a difference b/w YUV420 and YCbCr420?
Perhaps I'm doing something wrong but I can'ty get ippiBGRToYCbCr420_8u_AC4P3R to compile. "error C3861: 'ippiBGRToYCbCr420_8u_AC4P3R': identifier not found, even with argument-dependent lookup". ??
brian_barber
I found and fixed my compile problem. It works but the resulting image is more "washed-out" than if I removed the alpha channel using ippiCopy_8u_AC4C3R and then converted using ippiRGBToYUV420_8u_C3P3R. Do you have a guess why this might be?
thanks,
Brian
Vladimir_Dudnik
Hi Brian,
what do you mean under "washed-out"? Could you please attache sample of incorrect frame (and correct one if you have).
Vladimir
brian_barber
I attached my code as blend_snippet
The "washed out" bitmap (output_ycbcr.bmp)was created using ippiBGRToYCbCr420_8u_AC4P3R
The other bitmap (output_copy_removes_alpha.bmp) uses a copy to remove the alpha and then converts using ippiRGBToYUV420_8u_C3P3R.
Thanks for your help
Vladimir_Dudnik
Yes, I see, it was a bad idea, sorry. The reason is that in second case you convert from BGR to YCbCr and after that from YUV to RGB, but these functions use different equations to calculate out pixels (you can see IPP manual or ippcc.h file for the details)
// Y = 0.257*R' + 0.504*G' + 0.098*B' + 16
// Cb = -0.148*R' - 0.291*G' + 0.439*B' + 128
// Cr = 0.439*R' - 0.368*G' - 0.071*B' + 128
// Y' = 0.299*R' + 0.587*G' + 0.114*B'
// U = -0.147*R' - 0.289*G' + 0.436*B' = 0.492*(B' - Y' )
// V = 0.615*R' - 0.515*G' - 0.100*B' = 0.877*(R' - Y' )
Please submit new functionality request if you fill that the first suggestion does not fit your needs.
Vladimir
brian_barber
No problem. Thanks for the help
