Rotate YUV 4:2:2 video
marco_lopes
Hello All,
Im trying to rotate a yuv video 90 degrees but its not working as i expected
Im using ippiRotate 16u C1R, the rotate works but the colors are wrong.
Thank you in advance,
Marco
marco_lopes
Again, the function I'm using is:
ippiRotate_16u_C1R
I'm starting to consider, converting it to RGB, rotating and then converting back to YUV.
This sound very inefficient, there must be another way.
marco_lopes
Hi All,
I decided to go for the conversion first solution.
I convert it first using:
ippiYCbCr422ToBGR_8u_C2C3R
Then I use the rotate, everything looks fine.
Still I would like to know your opinion on how to skip the conversion step.
Thank you.
Vladimir_Dudnik
Please refer to IPP documentation on details of function naming convention. We use C1 for one-channels (gray) images and we use 16u for 16-bit per channel image, meaning that pixel value is in range from 0 to 65535.
We do not provide function which implement rotation on 4:2:2 sampled data so you need conversion step.
Vladimir
