Running Applicaiton with IPP in CygWin
thibeault__john
I have my test application built and running in MSVS 2015 using IPP and MKL on Windows 7 64bit OS.
I want to build the application using GCC and Eclipse (Oxygen).   I have installed Cygwin (v2.8.91) on my Windows 7 64 bit os.
I am able to build my application (from Eclipse launched from Start Menu) using "Cygwin GNU" tool chain referencing the IPP and MKS libraries from the installation location:
Library path (-L):
"C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.4.210\windows\ipp\lib\intel64_win"
"C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2017.4.210\windows\mkl\lib\intel64_win"
Library list (-l):
ippch
ippcv
ippdc
ippvm
ippcore
ippcc
ippi
ipps
mkl_rt
When I run my executable form the windows folder (outside of the CYGWIN file system) it fails before it gets to the first line of the main.
If I copy my application over to the Cygwin file system and run from Eclipse, it runs fine, but can't find the source files (outside of Cygwin).
I cloned by git repo in the Cygwin File system and tried to build the eclipse project inside of my Cygwin file system.  Eclipse won't run the compiler when I select the "Build" menu option on the Eclipse Application project.  I figure it can't resolve the absolute paths to the IPP and MKL object libraries.
Do I need to "install" or copy the IPP and MKL libraries into the Cygwin file system to link them and run in Cygwin?  If so, what specific files would be needed?
thanks,
John
thibeault__john
Can Intel provide a Cygwin 64 bit library for IPP?
