Simple mpg encoder...
runew
In our (CAD) application we have a simple video export option based on a stadard Microsoft codec package. The problems started with Vista, as this codec package refused to install. Therefore we're looking for another solution...
To put it simple, we have a set of frames/images that we'd like to encode to some kind of video that can be read by pure Windows intallations (Me/2000 and up). I guess plain old mpg1 would do the trick, but it isn't supported by IPP? Well, maybe some of the other supported formats would fit the bill...
I know next to nothing about video codecs, so I was hoping that there were some extremely simple (IPP based) examples out there, like:
encoder = InitEncoder(outFile, width, height, fps, quality [, numberOfFrames]);
encoder->AddFrame(image1);
encoder->AddFrame(image2);
encoder->AddFrame(image3);
encoder->Close();
I'm sure this is TOO simple, and that I'm hoping for too much (and that I'm over my head), but if there was an example that was somewhere in the neighborhood, I'd be very happy if anybody pointed to it for me :-)
Vladimir_Dudnik
I would recommend you to take a look on IPP media sample, which contains big bunch of codecs and test applications:
simple_player for playback and
video_encoder_con to encode frames.
Moreover, IPP encoders and decoders are threaded and you will automatically get benefit in performance from modern Core 2 Duo (or old SMP) systems.
Vladimir
runew
vdudnik:
Vladimir
Sorry, but I cannot find any mention of video_encoder_con anywhere in the IPP media sample package... :-(
Vladimir_Dudnik
Well, the correct name for IPP 5.2 beta is umc_video_enc_con, it is located in media_sampleapplications folder
Vladimir
runew
Found it. Thank you so muchsmiley [:-)]
I've tried the encoder, but it only outputs garbage. I suspect that this is because it requires YUV encoded files, and we export RGB encoded frames.
I'm trying to skip the entire usage of "YUVReader" and read single (RGB encoded) .jpg files instead. I sure hope this is possible...
Right now I'm messing about in VideoData trying to figure out what needs to be set for p_vidEncoder->GetFrame to work...
Vladimir_Dudnik
I think you need to add ippiRGBToYUV420_8u_C3P3R function to convert your RGB data to format which is required by YUV reader. The reason is that UMC encoders take YUV420 format as an input (otherwise conversion is required)
Vladimir
runew
Thank you Vladimir, for your patience...
Oh my God, this whole IPP thing sure is low level... I'm starting to wonder if this is really something to bother getting into after all...
I've noticed that several on this forum have asked for help reading jpg files, but as far as I've seen none has gotten any tangible answers... I've scoured through the image and media examples, but haven't found anything that helps me.
Too ba, as I'm so close to getting something useful!
All I want to do is to read a jpg file and use this data to fill in what's needed into the p_dataIn structure to be used in the followin call umc_video_enc_con example:
"mRetval = p_vidEncoder->GetFrame(p_dataIn, p_dataOut);"
In the example p_dataIn is provided by the YUVReader, which I was hoping to leave out alltogether by reading single jpg files.
Ah, well...
Vladimir_Dudnik
Well, IPP is Software Development Kit, which provides you optimized algorithms implementation and set of samples how to use that functionality. You need to spent some effort to integrate it into your application.
You can read JPEG files with CJPEGDecoder class from JPEGView sample.Then, you may convertdecoded image into VideoData representation with using ippiRGBToYUV420 function. UMC video encoder taakes VideoData as an input. Please read more details inUMC manual.
Let us know if youstill have any throubles with that, we will beglad to help you
Vladimir
runew
I'm so sorry, I hadn't downloaded the JPG samples as I though the JPG stuff was in the image samples... Talk about not using your eyes... :-(
I'll have a go at the JPG examples right now.
runew
I've scrapped the whole jpg thing, as the ultimate goal is to eventually get uncompressed image data from our host application. Right now I'm trying to read a sequence of .bmp files instead. All seems to go fine, but the result video file is all purple... Obviously I've done something wrong. I'm unsure about this whole ippiRGBToYUV420_8u_C3P3Rthing...I'm probably not populating the right buffers, but I'm unsure how to proceed. Here's the code snippet that is supposed to encode the video from sinle .bmp images:
// Encode video frame by frame
char frameName[512];
BYTE inBuf[1000000];
for (mFrameCount = 0; mFrameCount < maxNumFrames; mFrameCount++)
m_csysinfo.GetCpuUsage();
vm_string_printf(VM_STRING(
"Encoding frame: %d ... "), mFrameCount);
// Load bmp file into 'inBuf'
sprintf(frameName,
"v%05d.bmp", mFrameCount);
vm_string_fprintf(stderr, VM_STRING(
"Reading input file '%s' "), frameName);
FILE *inFile = vm_file_open(frameName, VM_STRING(
"rb"));
if (!inFile)
"Error: Can't open input file '%s' "), frameName);
err_code=9;
goto free_memories;
len = fread(inBuf, 1, 1000000, inFile);
if (inFile)
fclose(inFile);
// Get to the meat of the BMP file
unsigned int offset = (unsigned int)inBuf[10];
IppiSize roi = {mWidth, mHeight};
int dstStep[3];
dstStep[0] = dstStep[1] = dstStep[2] = 0;
Ipp8u* pDst[3];
pDst[0] = pY;
pDst[1] = pU;
pDst[2] = pV;
// Vladimir:
// I think you need to add ippiRGBToYUV420_8u_C3P3R function to convert your RGB data
// to format which is required by YUV reader. The reason is that UMC encoders take YUV420
// format as an input (otherwise conversion is required)
IppStatus ippStatus = ippiRGBToYUV420_8u_C3P3R(inBuf + (BYTE)offset, 0, pDst, dstStep, roi);
if (ippStatus != ippStsNoErr)
"ippiRGBToYUV420_8u_C3P3R failed with status: %d " ), ippStatus);
ts = vm_time_get_tick();
te = vm_time_get_tick();
time += (
double)(vm_var64s)(te - ts) / (double)(vm_var64s)tf;
if (mRetval != UMC_OK && mRetval != UMC_NOT_ENOUGH_DATA)
"Error: encoding failed at %d source frame (exit with %d)! "), mFrameCount, mRetval);
err_code = 13;
break;
len = fwrite(p_dataOut->GetDataPointer(), 1, p_dataOut->GetDataSize(), outFile);
mCompSize += (
int)len;
if (len != p_dataOut->GetDataSize())
"Error: Couldn't write to output file '%s' "), DstFileName);
err_code=11;
goto free_memories;
// extend p_dataOut data size to buffer size
// assume data pointer isn't moved
p_dataOut->SetDataSize(p_dataOut->GetBufferSize());
" done "));
Vladimir_Dudnik
BMP uses BGR channel order, so you need to call ippiBGRToYCbCr420_8u_C3P3R
Vladimir
runew
Thank you again, Vladimir!
Although it din't help. This wasn't entirely surpricing, since the (dis)order of the RGB channels shouldn't cause the constant green or purple screen that I get in the final video.
I've done some more testing and found out the following:
If I run my modified umc_video_enc_con with different codecs:
codec File size Playability GSpot reports
m2 246 kB Yes (green screen) Codec Not Installed
m4 27 kB no
Direct show: 0x80040265: Cannot playback file. Format no suppoerted
h264 7 kB no
h263 failed - -
h261 failed - -
For h263 and h261 I got "Video encode initialization failed"
I've ran the build file at ipp_samplemedia, and some sub builds failed:
video_renders
audio_renders
umc_pipeline
audio_codecs
virtual_ac_5p1
umc_reverb_demo
simple_player
audio_codec_com_so
All others passed. I don't know if this has anything to do with my problems, but thought that I should mention it.
-Rune
but all video encoders passed.
Vladimir_Dudnik
Hi Rune,
IPP media sample should build without any problems. Did you read readme.htm first to see what might be needed for compilation of that sample? Can you attach log files for us to see what was the problem with build?
If you try to play mpeg2 encoded stream on windows system, you should know that Windows do not have mpeg2 decoder installed by default.
To see encoded video you can try simple_player application from IPP media sample, it supports all codecs provided in that sample (H.261, H.263, H.264, MPEG2, MPEG4, VC1)
Vladimir
runew
Hmmm.... the latest DirectX SDK I was able to install on my Win2000Pro computer, was "Microsoft DirectX 9.0 SDK (Summer 2004)"
I notice that this particular version is not listed in directx_sdk.bat.
I guess this is not good at all... Do you have a link to a DX DSK that is "accepted by" ipp5.1 and still installable under W2kPro?
runew
I've now tried installing the oldest DX SDK that is mentioned indirectx_sdk.bat, andcan confrim that is is not installable under W2kPro...
I have no idea how to proceed from here...
Vladimir_Dudnik
actually, I think you can use your old version of DX SDK (just need to tune path to headers and libraries in directx_sdk.bat). DX functionality is mainly used in renders.
Vladimir
runew
I finally just copied the two missing lib files from the DX SDK to the lib directory in the media tree. Now a build32 passes all sub builds without problems.
BUT
My encodings still works as before m2, m4 & h264creates very small (and unreadable) video files and h261 & h263 results in the following message:
"Error: Video encoder initialization failed"
I've included the complete modified video_enc_con.cpp file. Hope you can see where I've made a fool of myself:
// INTEL CORPORATION PROPRIETARY INFORMATION
// This software is supplied under the terms of a license agreement or
// nondisclosure agreement with Intel Corporation and may not be copied
// or disclosed except in accordance with the terms of that agreement.
// Copyright(c) 2005-2006 Intel Corporation. All Rights Reserved.
#define
SINGLE_FRAME_ENCODING 1
#include
"..includeutils.h"
#include
"vm_time.h"
#include
"umc_sys_info.h"
#include
"vm_sys_info.h"
#define
MAX_FILELEN 1024
UMC :: SysInfo m_csysinfo;
int
encode(VideoEncoder *p_vidEncoder,
VideoEncoderParams *p_vidEncoderParams,
UMCReadYUV *YUVReader,
vm_char *DstFileName,
int *framesEncoded,
int *encoded_size,
double *enc_time)
VideoData *p_dataIn = NULL;
MediaData *p_dataOut = NULL;
int mFrameCount = 0, err_code = 0;
int mWidth, mHeight, mSize, maxNumFrames;
int mCompSize = 0;
Status mRetval = UMC_OK;
size_t len;
FILE *outFile = NULL;
vm_tick tf, ts, te;
double time = 0.0;
Ipp8u *pY = NULL, *pU = NULL, *pV = NULL, *pBS = NULL;
mWidth = p_vidEncoderParams->src_width;
mHeight = p_vidEncoderParams->src_height;
maxNumFrames = p_vidEncoderParams->numFramesToEncode;
mSize = mWidth * mHeight;
p_dataIn =
new VideoData;
p_dataOut =
new MediaData;
if ((!p_dataIn) || (!p_dataOut))
"Error: Can't allocate Media Data objects "));
err_code=7;
goto free_memories;
// Open output video file
outFile = vm_file_open(DstFileName, VM_STRING(
"wb"));
if (!outFile)
"Error: Can't open output file '%s' "), DstFileName);
err_code=9;
goto free_memories;
pY = pU = pV = pBS = NULL;
pY =
new Ipp8u[mSize];
pU =
new Ipp8u[mSize];
pV =
new Ipp8u[mSize];
pBS =
new Ipp8u[2*mSize];
if ((!pY) || (!pU) || (!pV)|| (!pBS))
"Error: Can't allocate data buffers! "));
err_code=10;
goto free_memories;
p_dataIn->InitAlloc(mWidth, mHeight, YUV420);
p_dataIn->SetDest(pY, pU, pV);
#ifndef
p_dataIn->SetPitch(YUVReader->mWidth, YUVReader->mWidthChroma, YUVReader->mWidthChroma);
#endif
// p_dataIn->SetColorFormat(YUV420);
p_dataOut->SetBufferPointer(pBS, 2*mSize);
tf = vm_time_get_frequency();
time = 0;
mCompSize = 0;
// HER KAN VI KANSKJE GJRRA NO?
#ifndef
if (YUVReader->LoadNextFrame(p_dataIn) != YUV_ERROR_NOERR)
"Error: Can't read next %d source frame! "), mFrameCount);
break;
#else
sprintf(frameName,
"rb"));
if (!inFile)
err_code=9;
goto free_memories;
if (inFile)
fclose(inFile);
// vm_string_fprintf(stderr, VM_STRING("Offset to image data '%d' "), offset);
int dstStep[3];
Ipp8u* pDst[3];
pDst[0] = pY;
pDst[1] = pU;
pDst[2] = pV;
// Vladimir:
// IppStatus ippStatus = ippiRGBToYUV420_8u_C3P3R(inBuf + (BYTE)offset, 0, pDst, dstStep, roi);
IppStatus ippStatus = ippiBGRToYCbCr420_8u_C3P3R(inBuf + (BYTE)offset, 0, pDst, dstStep, roi);
"ippiRGBToYUV420_8u_C3P3R failed with status: %d "), ippStatus);
#endif
time += (
err_code = 13;
break;
mCompSize += (
int)len;
err_code=11;
goto free_memories;
p_dataOut ->SetDataSize(p_dataOut->GetBufferSize());
" done "));
if (mRetval == UMC_OK && mFrameCount > 0)
do
mRetval = p_vidEncoder->GetFrame(NULL, p_dataOut);
time += (
if (mRetval != UMC_OK && mRetval != UMC_END_OF_STREAM)
"Error: encoding failed at outputing buffered frames (exit with %d)! "), mRetval);
err_code = 13;
// Incorrectly processed buffered frames encoding request!!!
break;
mCompSize += (
int)len;
err_code=12;
goto free_memories;
// mFrameCount++;
while ((mRetval == UMC_OK )&&(p_dataOut->GetDataSize()>0));
free_memories:
if (p_dataIn) delete p_dataIn;
if (p_dataOut) delete p_dataOut;
if (pY) delete [] pY;
if (pV) delete [] pV;
if (pU) delete [] pU;
if (pBS) delete [] pBS;
if (outFile) fclose(outFile);
*framesEncoded = mFrameCount;
*encoded_size = mCompSize;
*enc_time = time;
return err_code;
void
PrintHelp(vm_char *prog_name, vm_char *err_message)
"Error: %s "), err_message);
"Usage1: %s [m2|m4|h264|h263|h261] [Options] InputParFile OutputEncodedFile "), pro g_name);
"Usage2: %s [m2|m4|h264|h263|h261] [Options] -i InputYUVFile -o OutputEncodedFile "), prog_name);
"Options: "));
" [-i inputFile] - input YUV video file "));
" [-w width] - video width "));
" [-h height] - video height "));
" [-f frameRate] - video frame rate (frames per second) "));
" [-b bitRate] - encoded bit rate (bits per second) "));
" [-n numFrames] - max frames to encode "));
" [-t num] - number of threads for encoding "));
" [-r] - enables threading of read/encode/write "));
" [-y dir] - directory of YUV files "));
" [-u file] - file for dumping perfomance info "));
" [-p file.csv] - file for dumping perfomance info into scv format "));
"Note: Options -i,-w,-h,-f,-b,-n override corresponding values inside InputParFile. "));
" If InputParFile not specified, at least options -w,-h should be specified and -o should be added before OutputEncodedFile. "));
#define
GET_OPTION_POINTER(PTR)
if (2 == vm_string_strlen(argv)) {
i++;
if (argv[0]=='-') {
PrintHelp(argv[0], VM_STRING(
"in options"));
return 1;
else {
PTR = argv;
else {
PTR = argv + 2;
#define
CREATE_ENCODER(CODEC)
p_vidEncoder = create
##CODEC##VideoEncoder();
if (ParFileName) {
p_vidEncoderParams =
new CODEC ##EncoderParams;
if (Read##CODEC##EncoderParams(ParFileName,
(CODEC
##EncoderParams*)(p_vidEncoderParams),
SrcFileName,
MAX_FILELEN))
"Error: Can't read par file %s "), ParFileName);
err_code=3;
goto exit;
int
main(int argc, vm_char *argv[])
vm_char SrcFileName[MAX_FILELEN];
vm_char *pSrcFileName = NULL;
vm_char *ParFileName = NULL;
vm_char *DstFileName = NULL;
vm_char PerfFileName[MAX_FILELEN];
vm_char *pVal;
UMCReadYUV YUVReader[1];
VideoEncoder *p_vidEncoder = NULL;
VideoEncoderParams *p_vidEncoderParams = NULL;
ColorFormat mColorFormat = YV12;
FILE *perf_file = NULL;
FILE *perf_file_csv = NULL;
vm_char *p;
int encoded_size;
double enc_time, ov_time;
vm_tick tf, ts, te;
int numThreads = 1;
int rw_threading = 0;
int codec_number = 0;
int err_code = 0;
int i;
double size_ratio = 0;
int mWidth = 0, mHeight = 0, maxNumFrames = 0, mFramesEncoded = 0;
int BitRate = -1; // if (BitRate < 0) used below !!
double FrameRate = 0;
UMC :: sSystemInfo* m_ssysteminfo;
vm_char tmpbuf[128]={0,};
vm_char vid_type[15]={0,};
vm_char* stream_name = NULL;
*SrcFileName = 0;
*PerfFileName=0;
for (i = 1; i < argc; i++)
if (vm_string_strcmp(argv, VM_STRING("m2")) == 0) {
codec_number = 2;
else
if (vm_string_strcmp(argv, VM_STRING("m4")) == 0) {
codec_number = 4;
else
if (vm_string_strcmp(argv, VM_STRING("h264")) == 0) {
codec_number = 264;
else
if (vm_string_strcmp(argv, VM_STRING("h263")) == 0) {
codec_number = 263;
else
if (vm_string_strcmp(argv, VM_STRING("h261")) == 0) {
codec_number = 261;
else
if ('-' != argv[0]) {
if (NULL == ParFileName) {
ParFileName = argv;
else {
DstFileName = argv;
else
switch (argv[1])
case 'y':
i++;
vm_string_strcpy(SrcFileName, argv);
p = SrcFileName + vm_string_strlen(SrcFileName) - 1;
if (*p != '' && *p != '/') {
vm_string_strcat(SrcFileName, VM_STRING(
break;
case 'p':
case 'P':
i++;
vm_string_strcpy(PerfFileName, argv);
break;
case 'w':
GET_OPTION_POINTER(pVal);
mWidth = (
int)vm_string_atol(pVal);
break;
case 'h':
mHeight = (
break;
case 'f':
vm_string_sscanf(pVal, VM_STRING(
"%lf"), &FrameRate);
break;
case 'b':
BitRate = (
break;
case 'n':
maxNumFrames = (
break;
case 'i':
GET_OPTION_POINTER(pSrcFileName);
break;
case 'o':
DstFileName = pVal;
break;
case 't':
numThreads = (
break;
case 'r':
rw_threading = 1;
break;
case 'u':
i++;
perf_file = vm_file_open(argv, VM_STRING(
"w"));
break;
//case 'h':
case '?':
default:
"Unknown options"));
return 1;
if (!ParFileName && !codec_number) {
codec_number = 2;
if (!DstFileName) {
"Destination file name not found"));
return 1;
if (!codec_number) {
"Unknown codec"));
return 1;
if (!ParFileName && (!mWidth || !mHeight)) {
"at least ParFile or options -w,-h should be specified"));
return 1;
switch (codec_number) {
#ifdef
UMC_ENABLE_MPEG2_VIDEO_ENCODER
case 2:
vm_string_strcpy(vid_type,VM_STRING(
"MPEG2"));
CREATE_ENCODER(MPEG2)
if (ParFileName) {
int chroma_format = ((MPEG2EncoderParams*)p_vidEncoderParams)->m_Params.chroma_format;
if (chroma_format == CHROMA422) mColorFormat = YUV422; else
if (chroma_format == CHROMA444) mColorFormat = YUV444;
break;
#endif
/* UMC_ENABLE_MPEG2_VIDEO_ENCODER */
#ifdef
UMC_ENABLE_MPEG4_VIDEO_ENCODER
case 4:
"MPEG4"));
CREATE_ENCODER(MPEG4)
break;
#endif
/* UMC_ENABLE_MPEG4_VIDEO_ENCODER */
#ifdef
UMC_ENABLE_H261_VIDEO_ENCODER
case 261:
"H261"));
CREATE_ENCODER(H261)
break;
#endif
/* UMC_ENABLE_H261_VIDEO_ENCODER */
#ifdef
UMC_ENABLE_H263_VIDEO_ENCODER
case 263:
"H263"));
CREATE_ENCODER(H263)
break;
#endif
/* UMC_ENABLE_H263_VIDEO_ENCODER */
#ifdef
UMC_ENABLE_H264_VIDEO_ENCODER
case 264:
"H264"));
CREATE_ENCODER(H264)
break;
#endif
/* UMC_ENABLE_H264_VIDEO_ENCODER */
default:
"Codec (%d) not supported "), codec_number);
"Codec not supported"));
return 1;
if (!ParFileName) {
new VideoEncoderParams;
if (!maxNumFrames) {
maxNumFrames = 0x7fffffff;
if (!FrameRate) {
FrameRate = 30;
if (BitRate < 0) {
BitRate = 5000000;
// override param's if non-zero
if (mWidth && mHeight) {
p_vidEncoderParams->src_width = mWidth;
p_vidEncoderParams->src_height = mHeight;
else {
if (maxNumFrames) {
p_vidEncoderParams->numFramesToEncode = maxNumFrames;
else {
if (FrameRate) {
p_vidEncoderParams->FrameRate = FrameRate;
else {
FrameRate = p_vidEncoderParams->FrameRate;
if (BitRate >= 0) {
p_vidEncoderParams->BitRate = BitRate;
else {
BitRate = p_vidEncoderParams->BitRate;
p_vidEncoderParams->numThreads = numThreads;
if (NULL != pSrcFileName) {
vm_string_strcpy(SrcFileName, pSrcFileName);
m_ssysteminfo = (UMC::sSystemInfo *)m_csysinfo.GetSysInfo();
if(PerfFileName[0])
perf_file_csv = vm_file_open(PerfFileName, VM_STRING(
"a"));
if(perf_file_csv){
stream_name = vm_string_strrchr(SrcFileName, (
int)(''));
if(!stream_name)stream_name = SrcFileName;
else stream_name++;
fseek( perf_file_csv, 0, SEEK_END);
if(!ftell( perf_file_csv))
vm_string_fprintf(perf_file_csv, VM_STRING(
"Date,Time,Comp.name,OS,CPU,Num.CPU,CPU freq.,MEM,VGA,App,App description,Ver.,Streams(S) name,Status,S.Type,S.Res.,S.FR,S.BR,Video(V)Type,V.Format,V.Num,V.D/E(FpS),V.D/E(MHz),Compr.(%%),CPU Usage (%%),Max Cpu Usage (%%),Work.Time "));
vm_sys_info_get_date(tmpbuf,MMDDYY);
vm_string_fprintf(perf_file_csv,VM_STRING(
"%s,"), tmpbuf);
vm_sys_info_get_time(tmpbuf,HHMMSS);
"%s,"), tmpbuf);
"%s,"), m_ssysteminfo->computer_name);
"%s,"), m_ssysteminfo->os_name);
"%s,"), m_ssysteminfo->proc_name);
vm_string_fprintf(perf_file_csv,VM_STRING("%d,"), m_ssysteminfo->num_proc);
vm_string_fprintf(perf_file_csv,VM_STRING("%.2f,"), (double)m_ssysteminfo->cpu_freq);
vm_string_fprintf(perf_file_csv,VM_STRING("%d,"), m_ssysteminfo->phys_mem);
vm_string_fprintf(perf_file_csv,VM_STRING("%s,"), m_ssysteminfo->video_card);
vm_string_fprintf(perf_file_csv,VM_STRING("%s,"),m_ssysteminfo->program_name);
vm_string_fprintf(perf_file_csv,VM_STRING("UMC Video Encoder Con.,"));//,m_ssysteminfo->description);
",")); // ver. of aplications
"%s,"), stream_name);
"FAIL "));
fclose(perf_file_csv);
if (ippStaticInit() < ippStsNoErr) {
"Error: Can't initialize ipp libs! "));
err_code=5;
goto exit;
if (p_vidEncoder->Init(p_vidEncoderParams) != UMC_OK) {
"Error: Video encoder initialization failed "));
err_code=6;
goto exit;
if (p_vidEncoder->GetInfo(p_vidEncoderParams) != UMC_OK) {
"Error: Video encoder GetInfo failed "));
err_code=7;
goto exit;
// if (YUVReader->Init(SrcFileName, mWidth, mHeight, mColorFormat) != YUV_ERROR_NOERR){
// vm_string_fprintf(stderr, VM_STRING("Error: Can't initialize yuv data reader for file %s "), SrcFileName);
// err_code=8; goto exit;
"Starting encoding %s to file %s "), SrcFileName, DstFileName);
"Source video width = %d, height = %d, frameRate = %.2lf "),
mWidth, mHeight, FrameRate);
"Ma x frames to encode = %d "), maxNumFrames);
if (p_vidEncoderParams->BitRate > 0)
"Encoding bit rate = %d bits per second "), p_vidEncoderParams->BitRate);
else
"Encoding without rate control "));
if (!rw_threading) {
encode(p_vidEncoder, p_vidEncoderParams, YUVReader,
DstFileName, &mFramesEncoded, &encoded_size, &enc_time);
else {
"Enabled threading of read/encode/write! "));
encode_threaded(p_vidEncoder, p_vidEncoderParams, YUVReader, DstFileName, &mFramesEncoded, &encoded_size, &enc_time);
ov_time = (
if(PerfFileName[0])
"r+"));
if(perf_file_csv) {
fseek( perf_file_csv, -6, SEEK_END);
"PASSED,"));
"PV,"));
"%dx%d,"),p_vidEncoderParams->dst_width,p_vidEncoderParams->dst_height);
"%.2lf,"),p_vidEncoderParams->FrameRate);
"%d,"),p_vidEncoderParams->BitRate/1000);
"%s,"), vid_type);
"%d,"), mFramesEncoded);
"%.2lf,"), mFramesEncoded/enc_time);
"%.2lf,"), (double)(p_vidEncoderParams->FrameRate/(mFramesEncoded/enc_time)*(m_ssysteminfo->cpu_freq)));
"%.2lf,"), ((double)encoded_size*100.0/(mFramesEncoded*YUVReader->mFrameSize)));
"%.2lf,"), m_csysinfo.GetAvgCpuUsage());
"%.2lf,"), m_csysinfo.GetMaxCpuUsage());
"%02d:%02d:%02d.%02d,"),(int)ov_time/3600,(int)(ov_time)%3600/60,(int)ov_time%3600%60,(int)((ov_time-(int)ov_time)*100));
"Summary: "));
" Num frames encoded = %d "), mFramesEncoded);
" Encoding Time = %.2f sec, %.2f fps "), enc_time, mFramesEncoded/enc_time);
" Overall Time = %.2f sec, %.2f fps "), ov_time, mFramesEncoded/ov_time);
" Encoded Size = %d bytes "), encoded_size);
" Compression Ratio = %.2f "), ((double)mFramesEncoded*YUVReader->mFrameSize)/encoded_size);
if (p_vidEncoderParams->FrameRate > 0 && p_vidEncoderParams->BitRate > 0) {
size_ratio = encoded_size/(((
double)mFramesEncoded/p_vidEncoderParams->FrameRate)*(p_vidEncoderParams->BitRate/8));
" EncodedSize/ExpectedSize = %.2f "), size_ratio);
#ifdef
if (codec_number == 2) {
p_vidEncoder->GetInfo(p_vidEncoderParams);
" MPEG2 internal performance = %6.2lf fps "), ((MPEG2EncoderParams*)p_vidEncoderParams)->m_Params.performance);
#endif
if (perf_file != NULL) {
vm_string_fprintf(perf_file, VM_STRING(
"Performance = %.2f fps"), mFramesEncoded/enc_time);
vm_string_fp rintf(perf_file, VM_STRING(
", EncodedSize/ExpectedSize = %.2f"), size_ratio);
fclose(perf_file);
exit:
if (p_vidEncoder) delete p_vidEncoder;
if (p_vidEncoderParams) delete p_vidEncoderParams;
return err_code;
runew
If you could please help me... I've only changed the code from line 92 to 135, so you don't have to look through the entire thing to see what I've done :-)
Sorry if this is to stupid a request. If it is so, please tell me and I've try elsewere to find answers...
-Rune
Vladimir_Dudnik
I'll ask our experts to take a look on this
Vladimir
runew
Thank you so very much!
-Rune
Vladimir_Dudnik
Hi, there is some advices from our experts:
line 62 (numbers could have been shifted): change InitAlloc to Init, because external buffer is used.
line 105 pDstStep should be filled with proper pitches, not zeros: pDstStep[0] = (int)p_dataIn->m_lPitch[0]; etc for 1 and 2.
line 116: in ippiBGRToYCbCr420_8u_C3P3R call 2nd argument should be set (srcStep). 3*mWidth, I guess.
Please also check if mWidth and mHeight are correct, that bitrate (in bits/sec) isnt too small, that bmp file fits into 1000000 size.
If width and height are not multiple of 16 they should be extended.
Also note that different codecs require .par files of different format, if used. Lines order should be kept.
It would be nice if command line, .par file if any and one .bmp file have been provided.
Vladimir
