6847 Discussions
Splitter SetTimePosition problem with PCM (*.wav)
Sascha
if I try "m_pSplitter->SetTimePosition(0.0)" on the wav-file, I have sound problem,
without "SetTimePosition" all works fine, also without sound interference.
I have attached the screenshot so you can see what I mean.
Chao_Y_Intel
could you suggest which version of IPP sample, and what sample code you are using? That may help to have some further check on the problem.
thanks,
Chao
Sascha
I am using UMC 7.0.2. I have written my own application based on ".\ ipp-samples\audio-video-codecs"
I think, I have found the problem:
\codec\demuxer\src\umc_stream_parser.cpp
void StreamParser::Reset(void)
m_ParserState = HEADER;
if (m_pPacket) m_pPacket->Reset();
I have change this function to:
m_uiTracks = 0; //set back the tracks number
On the screenshot(see my first post) is the header data the reason of sound problem.
