The IPP sample's simple_player can't run
gzntiszj
Dear all,
I just installed Intel C++ Studio XE 2011 for Windows and the IPP samples. Mysystem is Windows 7.And I can compile and build the simple_player with vs.net 2008successfully which is in "w_ipp-samples_p_7.0.2.048\\ipp-samples\\audio-video-codecs\\application\\simple_player". But when I run the simple_player.exe, it just prompts an error that is "The program can't start because MSVCR90D.dll is missing from your computer. Try reinstalling the program to fix this problem."
Dose anyone experienced the same problem? Have you find the solution? Any suggestions will be helpful.
ntiszj
Chao_Y_Intel
Hi ntiszj,
I built the sample at 64 bit Windows 7, and do not see any problem. This looks like an manifest setting at your project. The following post may provide some help:
http://social.msdn.microsoft.com/Forums/en/vcgeneral/thread/8f08777b-1c4d-4e10-89a2-f7bc95cf5e98
Chao
Naveen_G_Intel
Canyou try with these options....
1.Build for Release, not Debug.
2. Turn of incremental linking (Project/Properties -Linker- Enable Incremental Linking)
Let me know how it works....
Naveen Gv
gzntiszj
Hi, Naveen Gv,
Thanks for you reply first.
I just checked it. I use the release build. And I set the simple_player's "Enable Incremental Linking" as No.
But I don'tchange other projects' property that are in the same sulotion. That is to say, projects including umc, all kinds of codec's property are not changed.
The result is:
Compile and build are still successful, but when run, it prompt "The program can't start because MSVCR90.dll is missing from your computer. Try reinstalling the program to fix this problem."
ntiszj
Chao_Y_Intel
Hi ntiszj,
Chao
gzntiszj
Thanks for Chao Y's tip.
I check the simple_player'sproperty: Linker->Menifest File->Generate Manifest.
My default value is No. I change it to Yes. And it work.
Thank you very much!
ntiszj
