6845 Discussions
The different output between run application under debugger (F5) and without debugger (Ctrl + F5) in visual studio
Tam_N_
Hi all,
I have a problem with my source code.
I used IPP function to calculate matrix but the output value is different when I run application under debugger (F5) and without debugger (Ctrl + F5) in visual studio.
Do you help me explain clearly about it ?
Tam Nguyen
Igor_A_Intel
Hi Tam,
could you share the reproducible of your issue? The difference between <F5> and <Ctrl F5> is that under debugger all allocated memory is set to some "debug" value, while without debugger it contains just a garbage. Therefore the first preliminary diagnose is that there is bug with memory boundaries - either in your application or in IPP function - somebody processes uninitialized data/memory.
regards, Igor.
