The performance
ken_chan
I'm testing the simple_player on P4 and core 2 duo. I expect that IPP will have better performance on core 2 duo. But the result was not. Core 2 Duo cost the cpu usage between 50 to 70 % ( event more ).
Is there any thing wrong?
my hardware spec is :
Inter Core to Duo 6600 , 2GB RAM, ATI X1600 Graphic card
The video clip is 720x480 with 30FPS
my command is : simple_player -v dx VideoClipName
Need your help~
Ken
Vladimir_Dudnik
Hi Ken,
what compression algorithm was used in yourvideo clip (I want to know what decoder work in simple_player)?
what version of IPP did you use? Do you know that the latest release version is IPP 5.1 and IPP 5.2 beta is available for evaluation? Can you update IPP binaries and media sample sources from the latest version?
Vladimir
ken_chan
Hi Vladimir,
Thanks for your reply.
The video clip isMpeg4. Yes, I'm using 5.2 beta.
Ken
Vladimir_Dudnik
Hi Ken,
could you please to print somewhere in the beginning of your program (but after call of ippStaticInit) version of IPP, to see what optimized code was loaded by IPP dispatcher?
You can do this with simple piece of code like this:
 const IppLibraryVersion* ippvc = ippvcGetLibVersion();
 printf("Intel Integrated Performance Primitives
printf(" version: %s, [%d.%d.%d.%d] ",
ippvc->Version, ippvc->major, ippvc->minor, ippvc->build, ippvc->majorBuild);
printf(" name: %s ", ippvc->Name);
printf(" date: %s ", ippvc->BuildDate);
Vladimir
ken_chan
Hi Vladimir,
Here is the information.
On P4
version: 5.2 beta, [5.2.291.35]
date: Oct 10 2006
On Core2Duo
date: Oct 10 2006
Ken
Vladimir_Dudnik
Hi Ken,
on Core 2 Duo performance should be better for sure. So, I'm trying to find a reason. What is the video card on your P4 systems?
Our MPEG4 decoder (and encoder as well) is threaded, and so it should utilize both cores. If you play video in maximum speed the cpu usage should be higher on Core 2 Duo. But if you do usual playback, cpu usage of course should be lower.
Vladimir
ken_chan
Hi Vladimir,
My Video card on P4 is ATI MOBILITY RADEON (IBM Notebook X32).
I used the same test program and mechanisms on both P4 and C2D.
Thanks again and hope to hear from you soon.
Ken Chan
Vladimir_Dudnik
Hi Ken,
it is strange, but we can't reproduce such issue. Did you tried different video streams?
Note, MPEG4 decoder and encoder are threaded with using OpenMP API, so you run them at the maximum speed they should utilize processor more (they will use both cores) then non threaded version (like when you run them on single core system. But, if you run decoder like you mention, to keep desired frame rate, they should defintely use processor less.
Vladimir
ken_chan
Hi Vladimir,
My video stream is standard with ISO 14496-2. Some decoders like DivX, XVid, FFMpged were working finewith it.I think IPP should be betterfor cpu usage. But the result isreally strange. :'(
For you to reproduce the issue. If that is possible, did any thing I can help?To provide the video stream?
Ken Chan
Vladimir_Dudnik
Ken,
if you can provide problem stream it would be nice and will help us inreproducing that issue
Vladimir
ken_chan
Dear Vladimir,
I uploaded the video stream as a file @ http://actiftp.hosting4less.com/Intel/, and the file name is "ForIntel.rar".
Please feel free to let me know ifanything needs me.
Ken Chan
Vladimir_Dudnik
Thank you, I'll pass it to our experts for analises
Vladimir
ken_chan
Hi Nikolay,
Yes, i tried to play the video plip with -n, but the CPU usage have no different to without -n( still cost 50 - 70 ).
Regrards,
Ken Chan
ken_chan
Hi Nikolay,
Here is the log. My command is "-vdx -n ForIntel.raw", I add the log for version, name, date last time request by Vladimir.
date: Oct 10 2006
Video Render :GDI
-RenderFormat:YV12
Stream Type :MPEG4PV
Video Info :
-Video Type :MPEG4
-Resolution :720x480
-Frame Rate :0.00
Audio Info :
-Audio Type :UNDEF
-S.Frequency :0
-Num.Channel :0
-BitPerSample:0
DecRate:774.97 fps(Dec 1.18ms/f + Conv 0.11ms/f = 1.29ms/f) RndrRate 31.99fps Audio Dec 0.00chnls
DecRate:1034.18 fps(Dec 0.87ms/f + Conv 0.10ms/f = 0.97ms/f) RndrRate 32.00fps Audio Dec 0.00chnls
DecRate:1044.06 fps(Dec 0.86ms/f + Conv 0.10ms/f = 0.96ms/f) RndrRate 32.00fps Audio Dec 0.00chnls
DecRate:1045.93 fps(Dec 0.85ms/f + Conv 0.10ms/f = 0.96ms/f) RndrRate 32.00fps Audio Dec 0.00chnls
DecRate:1039.28 fps(Dec 0.86ms/f + Conv 0.11ms/f = 0.96ms/f) RndrRate 32.00fps Audio Dec 0.00chnls
Ken
