Transpose of 32f complex matrix
ZVere
Is there an IPP API for this purpose ?
Till now I found transpose only for float matrix.
I did not find documentation for the mod value (32f_C1R, 32f_C3R, ...)
Thank you,
Zvika
ZVere
The right mod for in-place is C1IR.
It seems there is no API for complex - float matrix.
Am I right ?
Thank you,
Zvika
Gennady_F_Intel
Zvika,
see what the latest IPP 2019.4 supports wrt to transopising an image:
extracted from ippi.h file
IPPAPI(IppStatus, ippiTranspose_8u_C1R, ( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_8u_C3R, ( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_8u_C4R, ( const Ipp8u* pSrc, int srcStep, Ipp8u* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_8u_C1IR, ( Ipp8u* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_8u_C3IR, ( Ipp8u* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_8u_C4IR, ( Ipp8u* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16u_C1R, ( const Ipp16u* pSrc, int srcStep, Ipp16u* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16u_C3R, ( const Ipp16u* pSrc, int srcStep, Ipp16u* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16u_C4R, ( const Ipp16u* pSrc, int srcStep, Ipp16u* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16u_C1IR, ( Ipp16u* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16u_C3IR, ( Ipp16u* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16u_C4IR, ( Ipp16u* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16s_C1R, ( const Ipp16s* pSrc, int srcStep, Ipp16s* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16s_C3R, ( const Ipp16s* pSrc, int srcStep, Ipp16s* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16s_C4R, ( const Ipp16s* pSrc, int srcStep, Ipp16s* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16s_C1IR, ( Ipp16s* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16s_C3IR, ( Ipp16s* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_16s_C4IR, ( Ipp16s* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32s_C1R, ( const Ipp32s* pSrc, int srcStep, Ipp32s* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32s_C3R, ( const Ipp32s* pSrc, int srcStep, Ipp32s* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32s_C4R, ( const Ipp32s* pSrc, int srcStep, Ipp32s* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32s_C1IR, ( Ipp32s* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32s_C3IR, ( Ipp32s* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32s_C4IR, ( Ipp32s* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32f_C1R, ( const Ipp32f* pSrc, int srcStep, Ipp32f* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32f_C3R, ( const Ipp32f* pSrc, int srcStep, Ipp32f* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32f_C4R, ( const Ipp32f* pSrc, int srcStep, Ipp32f* pDst, int dstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32f_C1IR, ( Ipp32f* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32f_C3IR, ( Ipp32f* pSrcDst, int srcDstStep, IppiSize roiSize ))
IPPAPI(IppStatus, ippiTranspose_32f_C4IR, ( Ipp32f* pSrcDst, int srcDstStep, IppiSize roiSize ))
ZVere
Hi Gennady,
Thank you very much !
Zvika
